Question about Sony PlayStation 2 (PS2) Console
My tray is stuck got the top and bottom off need help to get it unjammed
Posted by wizardrocksm on
khorianne5
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 273 Answers
  • khorianne5 Sep 03, 2011
    Copy and paste the web address.
    For some reason, the link doesn't work.
LG French door bottom freezer. The second pull out tray came off track. How do you fix it?
Examine the first pull out tray and install the second one the same way as the first .
Sep 05, 2017 | Refrigerators
The tray where ice falls is jammed how do i unjam it
Have you tried taking the ice out and seeing if its something stuck in there?
Jul 19, 2017 | Refrigerators
Icemaker jammed just as the teeth start rotating to loosen the ice. Any way to unjam it?
Seems that you will need a new ice maker. there is heater in the ice maker, if it does not come on, ice cubes will stuck. heater is under the tray of ice maker.
Jul 18, 2015 | Refrigerators
My Dishwasher door keeps springing open - how do I fix this?
Hello Colin;
My name is Peter. I am a retired field service appliance technician.
Push in the top and bottom trays. Close the door. Now, open the door. Are either the top or bottom trays pushed out?
In the bottom center is your water distribution vanes. Are they stuck up in the operating mode? Push the center water distribution vane down, push the top and bottom trays in, close the door and reopen. Are the upper or bottom tray sticking out? inspect the guide rails. Is there something blocking them?
So, your problem is:
1.) The trays are pushing against the door because they will not go in all of the way.
2.) You have a broken latch assembly.
You did not provide a model number. This is on a tag either on the top of the door or on the face of your dishwasher after you open the door.
May 16, 2015 | Dishwashers
Screen is showing CHECK PAPER error and will not clear.
Check on TOP of the bottom paper tray.
The NO paper sensor is "hanging" to sense no paper condition.
Free this sensor (it may got stuck or defective)
Jan 18, 2014 | Brother MFC-8840D All-In-One Laser Printer
How do I unjam paper in HL 2142
You open your printer (use your manual to correctly do this)
check all paper paths to see if any paper is stuck
Next take out the toner and drum and check again for any stray scraps of paper that may have been stuck there.
Also open the paper tray and look inside there to see if anything is stuck there.
If your printer has a single sheet tray check there too
If your printer has a back opening, check there too
I recomend that you also purchase "paper path cleaning sheets" to keep the unit clean and paper jam free (once a week if you print constantly and twice a month if a casual user)
NEVER NEVER NEVER get mad and RIP out stuck paper. Such an action will break internal mechanisms inside your laser printer.
Hope this helps Have a great day
Mar 06, 2010 | Brother HL-2040 Laser Printer
We need local repair person
I don't understand your website. I was charged 14.99 or so yesterday on my visa, but after your company accepted my payment, I learnedno one was available to help me. So I waited and this morning I have an email that is asking me to pay again or tell me how I fixed the problem.
It really is a simple problem that should be handled by you with a phone call rather than a lengthy internet procedure. I pulled out the toner tray and the bottom tray remained while the top came off and the powder spilled everywhere. I don't want to use a household vacuum on it. It is a mess. I need an approach to unhook the stuck bottom toner tray of the Mita DC 1455 (an old but serviceable copier) and replace the spilled toner with a new module. And how do I clean up spilled fine toner powder which is everywhere?
Jul 24, 2008 | Kyocera Mita FS 3800 Laser Printer
Stuck dvd in the machine on top of one in there already - cannot eject - help
If you are comfortable taking the cover off, you can try removing the cover and remove the dvd's yourself.
IF you are not comfortable removing the cover then, you can try to take a credit card (Actually, if you have any of those JUNK credit cards that the CC companies send out as trial offers, those work the best, and who cares if you bend those, they get tossed anyway) and bend an edge at a 90 degree.. (about 1/8" of the edge) so it makes like a small ledge. try to fit it inbetween the top of the door, and then see if you can open it up. Some players have a seperate door, and some trays are attached to the door. You might be able to help it out or unjam the tray this way.
And in the Future, with any other CD/DVD Players, use your remote control or the open and close button to open and close the tray, and NEVER Push on the tray itself. If I had a dollar for every dvd player tray that Ive fixed because of this, I would be buying bill gates dinner. (not really, but you get my point)
Good luck.
Mac =)
Please post a rating or feedback if I have answered your question.
Mar 21, 2008 | Televison & Video
Stuck dvd on top of other in player - need help!!!
If you are comfortable taking the cover off, you can try removing the cover and then try and remove the DVD by yourself.
IF you are not comfortable removing the cover then, you can try to take a credit card trick that has worked for me.(Actually, if you have any of those JUNK credit cards that the CC companies send out as trial offers, those work the best, and who cares if you bend those, they get tossed anyway) and bend an edge at a 90 degree.. (about 1/8" of the edge) so it makes like a small ledge. Try to fit it inbetween the top of the door, and then see if you can open it up. Some players have a seperate door, and some trays are attached to the door. You might be able to help it out or unjam the tray this way.
Good luck.
Mac =)
Please remember to leave a feedback and or rating if I have helped you with your problem.
Sony PlayStation 2 (PS2) Console Logo
166 people viewed this question
Top Sony Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Marvin
Marvin
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
