Lg unlocking does not need network, it only requires imei to get unlock code. Dial *#06# as you make a call, it pop`s up the imei of your phone. Send it to any unlock code provider, they send you the code after processing it
Network Unlock Code
Hello, try to asking to online unlock code seller. As my knowledge blackberry phones still can unlocked even we don't know the original network sim card. Blackberry can use MEP to finding out what is the original network. Or you can try LG GW300 unlock code based on original country of your phones. I means try to find LG unlock code for your phones at online store based on original country not by network. I hope my solution can solve your problem.
I recomended you to doing cable unlocking process rather that use LG GW300 unlock code since you don't know what your phone origin network. This method was powerfull to unlock lg phone but more expensive rather use unlock code.
Warning : Do not enter
any wrong unlock codes on your LG GR500 Xenon mobile phones. If you
enter over a certain amount of wrong unlock codes on your LG GR500 Xenon
mobile phone, your phone may get hard locked and sometimes become
unusable.
1 - Switch on your LG GR500 Xenon with a NOT ACCEPTED* SIM Card.
2 - LG GR500 Xenon will display "phone restricted" Select "Cancel".
3 - LG GR500 Xenon will display "phone restriction code" Enter the Unlock code. Select "OK".
4 - The handset is now successfully unlocked.
*NOT ACCEPTED : We mean, to use a sim card from a network other than the network your LG GR500 Xenon is locked to.
(OR)
1 - Switch ON your LG GR500 Xenon with its ORIGINAL SIM Card.
2 - Enter2945#*9701#.
3 - A menu will pop up, Select Sim Unlock.
4 - Enter your Unlock Code and press OK.
5 - The LG GR500 Xenon will then reboot and the unlock is complete.
ORIGINAL: We mean, to use the sim card that was originally given to you by your network/service provider along with the LG GR500 Xenon.
(OR)
2 - Type *#865625#.
3 - Enter the unlock code twice.
4 - LG GR500 Xenon should say: Network Lock Deactivated.
5 - LG GR500 Xenon may automatically reboot and is now unlocked!
