Question about Samsung ML 1610 Laser Printer
My samsung ml1610 printer has red light online/error, with the smart panel installed it shows paper tray empty..but it isn't empty, it is with good amount of papers, i tried to remove and install the cartridge, check for paper jam( from main door and output part), reconnect all the cables, the toner is still with powder, wiped the roller with tissue, finally uninstall and reinstall the smart panel and ml1610 xp driver...nothing helps, still the same old paper tray empty red light error..in the end i gave up and restarted the comp and printer.. in amazement it give me a 2 green light on online/error and toner save and i understand that this is a system problem from ml1610 manual. now i donno wat to do, pls help
Posted by pschew_47 on
  • pschew_47 Aug 30, 2011
    First of all, thanks for answering, i've tried
    1. checking paper jam by pulling out the toner and look inside/feel inside for any paperbits & checking the paper output part.
    2. dismantle the cords and check for any loose connection
    3. check toner if it is still in good condition( still with powder)
    4. remove and reinstall ml1610 windows xp driver and smart panel.
    5. wipe roller with tissues?
    6. make sure there is good amount of paper in the tray.
    For the printer indication light, it shows RED online/error light w/o blinking.
    For info, sometimes....only sometimes..when I turn on the printer ..it shows 2 GREEN LIGHT W/O BLINKING, i checked it in the manual and this is NOT EXPLAINED, only 2 BLINKING GREEN is explained, mine is 2 green lights W/O blinking.
    After a short time, the 2 greens will turn to 1red.
    Which is where I am now.
    Thanks for reading all this.
  • pschew_47 Sep 05, 2011
    Is this what u want? There is drivers for XP, Vista and 32/64bit Window 7. http://driverscollection.com/?H=ML-1610&...
brian soufane
    President:
  • 693 Answers
To solve this problem, follow the link below and follow the instructions on the linked page on how to solve this problem. For me to give you instructions here, it would be too long so I set up this link that will take you to solve the problem you're having http://downloadcenter.samsung.com/content/UM/200709/20070911095810078_English.pdf
Posted on Aug 29, 2011
  • 1 more comment
  • pschew_47 Aug 29, 2011
    Paper jam occurs. To solve the problem, see
    “Clearing Paper Jams” on page 5.6.
    • The front cover is open. Close the front cover.
    • Paper tray is empty. Load the paper in the Tray.
    • The toner cartridge is out of toner. Remove the old
    toner cartridge and install a new one. See
    “Installing the Toner Cartridge” on page 2.4.
    Already tried all these earlier but still online/error indication light = red.
  • brian soufane Aug 30, 2011
    It probably has a jam somewhere. Open each flap, remove the toner cartridge and check the paper path is clear OR There has to be an obstruction to the paper path somewhere. Pull the toner cartridge out and have a good look, open the back panel up and see it is clear. I think you might find a foreign object in there or a small piece of paper as it doesn't take much to block the paper path. I hope this helps you
  • ankit
    ankit Oct 17, 2013
    i am stuck to the same problem
Smithmkt
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 68 Answers
Online Samsung Printer Technical Support at 1877-778-8!9!6! https://youtu.be/NqnArIsQ8R4 9 for USA'Canada. For More Info Click On: https://goo.gl/XJyUhV
Posted on May 03, 2017
totito12
    New Friend:
The driver not funk i need the driver plissss urgent!!!!!!!
Posted on Sep 04, 2011
Red light stays on... wont print wont pick up paper... cleaned as much as I could...
There are a lot of conditions that cause the red light to come on. These include toner cartridge empty, paper jam, waste toner tank full, etc. The only good way of determining the printer fault is to check the smart panel software on your computer. It will tell you what the printer is experiencing.
If the printer can't pick up the paper, check the condition of the paper pickup roller. It is located in the back, and above the paper tray. Often it get dirty and cleaning it with a damp cloth helps it to pick up paper better. Hope this helps you.
Dec 29, 2010 | Samsung CLP 300 Laser Printer
Why is red light on samsung clp- 315 and it is not printing
Does one of these situations apply to you?
The Status LED light is Red and the Toner lights are OFF (Check Smart Panel for message)
  • A Paper Jam has occurred.
  • The Front, Top, or Back Cover is open.
  • There is no paper in the Paper Tray.
  • There is a problem with the Waste Toner container.
  • A major error has occured.
The Status LED light is Blinking/Flashing Red and the Toner light(s) are Red
  • The Toner cartridge(s) that are Red need to be replaced. (Can still be used to print, but quality is unreliable)
The Status LED light is Red and the Toner light(s) are Red
  • The Toner cartridge(s) that are Red need to be replaced. (Printing is not available)
  • The Toner cartridge(s) are not installed properly.
Source: samsung troubleshooting guide for CLP-315
Sep 25, 2010 | Samsung CLP 315 Laser Printer
My ML1610 Samsung printer is not working. The red and green light are blinking simultaneusly and cancel button is struck. How can I set it right?
Dec 15, 2009 | Samsung ML 1610 Laser Printer
Samsung printer ml 1510 red light flashes after self test
Red Error Light Stays On The following conditions can cause the On Line LED to glow solid red:
  • Printer paper is jammed inside your printer.
  • A cover is not be closed properly.
  • The toner cartridge is not inserted properly and needs to be reinstalled.
  • The toner cartridge is running low.
  • There is no paper in the paper tray.
  • The paper inside the paper tray is not be installed correctly.
Red Error Light Blinks If your printer's On Line LED is blinking red, your printer's toner is exhausted and needs to be replaced. On Line and Error Light Blink Simultaneously
If your printer's On Line and Toner Save LEDs blink simultaneously, your printer requires service.
You can go to samsung online service request http://www.samsung.com/us/support/repaironline/supportOnlineServiceRequest.do
Mar 21, 2009 | Samsung ML 1510 Laser Printer
I have an ML1610 printer which has jammed - it failed to feed a sheet of paper. Now the red error light shows constantly. Is there a way to reset this?
if you open both the front and top flaps check theres no paper there and close them again this does the trick. Has always worked for me, anyway!
Sep 30, 2008 | Samsung Office Equipment & Supplies
ML1610 SAMSUNG PRINTER PROBLEM
The online/error light is always red, and I can't print. I turn the printer off, change the toner and the light is still red, what can I do
Sep 13, 2008 | Samsung ML 1610 Laser Printer
Samsung ml 2010 r laser printer
Check your manual, there is a solution there or download the user guide from
this site below or read the information below.
http://downloadcenter.samsung.com/content/UM/200602/20060216163720484_ML-2010_English.pdf
LED pattern Possible Problems and Solutions
Your system has some problems. If this problem occurs,
contact your service representative.
On Line/Error LED
lights red
• Paper jam occurs. To solve the problem, see “Clearing
• The toner cartridge is out of toner. Remove the old toner
cartridge and install a new one. See “Installing the Toner
• You pressed the Cancel button while the printer is
receiving data.
• In Manual Feed mode, there is no paper in the manual
tray. Load paper into the manual tray.
• If the printer is receiving data, the On Line/Error LED
slowly blinks green.
• If the printer is printing the received data, the On Line/
Error LED blinks green fast.
Jul 17, 2008 | Samsung ML 2010 Laser Printer
Printer ML2010 not responding
On Line/Error LED
lights red
receiving data.
Jul 15, 2008 | Samsung ML 2010 Laser Printer
Red and Green lights are together blinking continiously
I had this problem. The cancel button was stucked. Open the toner tray and slighly push the button side top-cover up. It released the cancel button for me (actually I was trying to open the top, but it worked). The cancel button was released and the blinking red-green stopped. Printer now working.
Mar 03, 2008 | Samsung ML 1610 Laser Printer
Samsung ML 1610 Laser Printer Logo
16,411 people viewed this question
Top Samsung Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
