Question about Uniden Solara DSC VHF Marine Radio
My radio transmits fine. Until recently it received fine. Now it transmits but it does not receive. I've played with the squelch and volume. No luck. Can you advise.
Posted by lanamullis on
Gary Rice
  • 1,851 Answers
Your finals are fried. Take it to a shop and they will fix the finals. Before you do that be sure to put in an extension speaker just to be sure. Most CB shops are inexpensive.
Posted on Aug 29, 2011
What's up I have a uniden Washington no sound out of the speaker but it is receiving you can tell by the s meter moving.?
do you have the volume turned up? Squelch turned all the way left and RF gain all the way right. If you still don't hear anything check to see if this model has a dynamic squelch .If it does turn it off.
Sep 30, 2014 | Radio Communications
I get no squelch on my cobra 75 wx. I can't receive when somone transmits near me.
that's normal . If someone near you has more power then you he will walk all over your signal . You just might be doing the same to them.
Nov 28, 2011 | Cobra 75 WX ST 40-Channels Handheld CB...
I have a Midland 75-785 hand held, It was working fine then I went to use it and the squelch control is not working ( I get lots of static) radio still works. Sends and receives, but when I turn the...
what time of day are we talking here? usually skip is so heavy from 0800 until 1600 that no radio has a chance of transmitting or receiving.If you turn the squelch the other way what does it do?
Jun 22, 2011 | Midland 75-785 Handheld CB Radio
Radio will receive but not send
The transmit final transistor is no good. it blew out. needs to be replaced.
Mar 17, 2010 | Radio Communications
BellSouth 1010 walkie talkie receives constant static
you have opened up the squelch - refer to the manual to close and return radio to normal operation
Aug 27, 2009 | BellSouth Radio Communications
NO SQUELCH
I have a Radio Shack Pro 97 Scanner that I received as a present 1-1/2 years ago. It was working just fine and then suddenly there was no squelch or volume. The keys make noise when pushed, but there is no sound for the squelch or volume. The scanner scans the frequencies but does not stop and play. I went on line and found that other people were having the same problems. I went back to the store that the unit was purchased from and received no help what so ever, they said it’ s off warranty and I was out of luck, nice way to do business??. I think that something that cost as much as this should not be junk after a short period of time. I hope you can help me with this problem I do like radio shack, but I can’t afford to buy items that don’t stand up.
Sincerely
Greg Stevens
e-mail
[email protected]
Aug 07, 2008 | Radio Shack Pro-97 Handheld Scanner
Problems setting up Motorolla GM300
It is either a programming problem, such as the Rx is not programmed correctly OR your radio needs to be looked at by a technician to determine the issue.
Jun 14, 2008 | Motorola GP300 Compatible 2 Way Radio...
Motorola FV500 2 way radio can send/cant receive
Do you hear the Beeps on the speaker? Check for the QT and the code squelch are the same in both radios, try to set code squelch in "0". Make sure that the radio is not receiving or the other one is not transmiting, with two radios will see the same.
Aug 09, 2007 | Motorola FV500 2-Way Radio
Uniden Solara DSC VHF Marine Radio Logo
847 people viewed this question
Top Uniden Boating Experts
Andrew Taylor
Andrew Taylor
ray gallant
Michel Laprise Sr
Are you an Uniden Boating Expert? Answer questions, earn points and help others
