Question about Zebra ZM400 Thermal Label Printer - ZM400-3001-3000T
Will not print onto the label. but can see it on the black ribbon reel.
Posted by matman_disco on
Label Queen
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 51 Answers
Perhaps your darkness is set too low, or your labels are not coated to accept thermal transfer printing. Let me know if this helps!
Posted on Sep 09, 2011
My journal tape is not printing.
Another common print problem with laser printers is light print or uneven print density across the page. This is caused by low toner. Take out the cartridge and gently rock it side to side to redistribute the toner. Then simply put it back in the printer, and you're good to go.
This can happen when you install the tape cassette leaving the ink ribbon loose, or by pulling the printed label out by hand. If the ink ribbon has not separated from the cassette, you can fix this by winding the toothed wheel and reeling the ink ribbon.
If all else fails, might need an update.https://support.microsoft.com/en-us/help/3162655/windows-journal-application-for-windows
Jul 12, 2018 | Office Equipment & Supplies
I have a brand new zebra tlp2844 I have set it up with a resin ribbon, the print quality is very poor and patchy why is this ?
There are a couple of possible solutions.
1/ Resin ribbons are meant to be used on synthetic labels onle ie vinyl or polyester. If you are trying to print on paper labels then you will get a rubbish print. you need to use either a wax ribbon or a wax resin ribbon.
2/ If you are printing onto a synthetic labels and the print is light, try increasing the "print darkness" some times called contrast or heat or printhead setting.. This can be fount in the printer set up in the labels software you are using or in the print drive under "Print Preference"
Dec 16, 2012 | Zebra TLP 2844-Z Thermal Label Printer
Have an Everest III disc printer that is not printing good labels. Seems the blue prints OK but the are streaks on the disc where the red and yellow should be printing. Changing the ribbons didn't
First thing is to completely CLEAN the printer. All rollers and any point that contacts the ribbons or transfer material.
John Norman
Max Optical llc.
www.maxoptical.com
Aug 08, 2012 | Rimage Office Equipment & Supplies
Ribbon is melting
Hi
You have the heat setting in the driver set too high.
Lower the heat setting to the lowest possible setting, the print quality will probably be poor then gradually increase it by 1 until print quality is good.
Regards
Rob
Plain, Printed and Barcode Labels
May 11, 2012 | Zebra Stripe S600 Thermal Label Printer
How do i replace ink cartridge
Remove the paper scroll from the printer. Turn off the power and make sure the print wheel has stopped moving.
Slide the printer cover toward the back of the machine to remove it. Lift out the old ribbon and replace it with the new one by facing the black side of the ribbon up. Secure one of the reels to its reel shaft, thread the ribbon around the outside of the metal guides, and secure the other reel to the opposite reel shaft.
Tighten any slack ribbon by turning one of the reels
Replace the print cover and reset the paper scroll.
May 02, 2011 | Sharp EL-2615G Calculator
Ribbon Label Stock Misalignment
There isn't any type of guide made to do that.
Feb 03, 2010 | Zebra 140XiIII Plus Thermal Label Printer
Take up reel not working on Monarch 9825 printer
Go into the printer's menu and turn on the ribbon, or if you are using a 3rd party software, go into the software settings to tell the printer that it has a ribbon.
If you go through the printer, use this document. Go to chapter 4, page 4.
http://www.monarch.averydennison.com/support/doclookup.asp?printer=9855&doctype=oh
Jan 04, 2010 | Paxar Monarch 9825 Thermal Label Printer
I channged the ribbon and the printer will not print tried several thing but it look like everything goes ok but there is nothing printed on the labels
Check that ribbon is installed correctly. Zebra ribbon only has ink on one side. ink side must be facing label. Use a label to check which side ink is on stick label onto ribbon and peel off.
Jun 14, 2009 | Zebra LP 2844 Thermal Printer
9855 ribbon take up reel not working
When you're sending data to the printer you're sending a command that is telling the printer you're NOT using a ribbon. When the printer receives the data it's shutting off the ribbon. Check your software.
You should be set for THERMAL TRANSFER.(RIBBON)
THERMAL DIRECT Means NO RIBBON
Feb 04, 2009 | Paxar Monarch 9855 Thermal Printer
Zebra ZM400 Thermal Label Printer - ZM400-3001-3000T Logo
268 people viewed this question
Top Zebra Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marvin
Marvin
Muntejaya Ginting
Muntejaya Ginting
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
