I also have the Maytag Neptune Front Loading Washing Machine, MAH5500BWW. BAD smell and I have cleaned it all inside and looked at all the posts. Just looked at the manuals and can't find a reference for the drain pump filter under any of their parts, do they use another term? I am assuming I have to go in from under the machine to drain it? Many thanks.
Hi The smell usually comes
when the washer is unable to drain water completely, you can run your washer at
its hottest temperature setting with 1 cup of vinegar inside the unit. After
this take off the bottom front panel and clean it completely, also clean the
drain hose and drain pump filter, the smell should disappear after doing all
this. Hope this helps...please post back for further assistance. Daniel
