SOURCE: I need a belt for my Shark Pursuit Euro-Pro X
I am unsure of the part number, but they have them for about $5 after shipping here:
http://www.totalvac.com/accessory/parts/sharkbelt.html
SOURCE: Shark Euro Pro upright vacuum V1310RS
Most vacuums you either remove the bottom plate, or the top cover comes off. If no screws on the top cover, then turn vac. over and remove the screws on the bottom. Then you should be able to get to the brush roll and belt.
SOURCE: I am trying to find
Hi Helen. Some times the best way to get a new belt is to simply take the old one to a vacuum store and they should be able to match you up with one. Hope this helps, Chris
SOURCE: Shark Pursuit Euro-pro X vacuum cleaner, 12 amp, upright model
This vacum cleaner is equipped for auto shut off when it gets hot , It gets hot when it gets clogged either the little sponge filter is to dirty or the the round white filter in the dust collecting container.
But if they are both clean then it is clogged in the line probably with lot of carpet fiber, in that case you ned to take the dust container out and possibly the assembly from bottom like when you change the belt, then take of the Handle where the flex hose is attached, then you gonna need a wire hanger bend a long shape close to the shape of the hose line from handle to where it curved around in the bottom opening where it collects the dust behind the spin brush the just stick the hanger from the handle side cause the clog is probably in the lower side then just push the clogs out . Be care full not to puncture the flex hose with hanger. Its probably a good idea to bent the tip of the hanger so that it wont poke hole in the flex hose.
That's what happened with mine I spend hours and hours and days to figure it out. I could have just through it away, but it just kind a pissed me off and the War was on as stubborn as i am, but finally I won and I got the satisfaction of the sweet victory.
Waste lot of time though but it just one of those things. It never messed with me again.
But that is what's wrong with it. Good luck it a good vacum though very power full.
