Question about Kodak EasyShare Z740 Digital Camera
Under MacOSX I have a Easyshare Z470 camera. Microprogram for camera 1.0100. When I connect my camera through a USB as usual, iPhoto recognize the camera and open as usual. But since 1 month, instead of the photos, I get only dashed squares in the iPhoto window were the photos normally appear (as many squares as there are photos). When I ask to import the photos, the following advise appear : " Files format not recognized " followed by the list in .jpg of the photos on the Disk. iPhoto can't read the files through the camera, and can't erase them. To get the pictures I must take out the SanDisk and insert it into a diskreader. Then everything works normally with the Disk and iPhoto. Exactly the same problem appears when I proceed from the internal memory of the camera. These photos are lost forever. The camera seams to be anymore unable to make the transfer between the SanDIsk and iPhoto, through the USB. The camera works normally in all other functions. I already formated the Disk and the inside memory with the camera. What must I do... Jean-Pierre Roy
    Brigadier General:
  • 11,967 Answers
Pro photographers avoid this very common problem by always using a diskreader. You've found that this method works very well so stop worrying and enjoy. As far as the problem with the pics on the internal memory of the camera, go into the menu and find "copy". It will give you the option to copy the internal memory to a memory card.
Posted on Aug 28, 2011
6ya staff
SOURCE:
How do I upload my photo's from my Finepix Z90 to my mac? I can't start installer for MacOSX on my Mac.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as iPhoto.
May 16, 2012 | Fujifilm Finepix Z90 Camera Digital 14MP -...
IPhoto stopped recognizing my camera. iPhoto was working until yesterday and now it doesn't. Image capture recognizes the camera but does not give the option to import. The USB port works. The hard...
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto.
Sep 30, 2011 | Panasonic Lumix DMC-FX3 Digital Camera
I can't get my new MacBook to recognize and import photos.
Mac's don't need a driver to recognize the camera however they usually need a specific program for different brands of photos. You can also try opening up iPhoto as that will usually recognize the camera. If iPhoto doesn't work and you don't want to install a new program you can also get a card reader that'll connect via USB and will avoid needing any program to transfer photos.
May 11, 2011 | Fuji FinePix S1000FD Digital Camera
The camera will charge and take pictures but I cannot load them on my computer. I have a Mac OS X computer. I used to be able to load them to my Kodak Gallery. Now my computer does not recognize my...
You might want to consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or EasyShare or any other photo cataloging program.
Jan 21, 2011 | Kodak EasyShare C340 Digital Camera
My Kodak EasyShare won't export to my MacBook or the MacBook isn't recognizing the camera. It has worked many times in the past. Help!
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Jan 02, 2011 | Kodak EasyShare V1003 Digital Camera
Canon Powershot S2 IS is not recognized on my iMac
Simple fix...use a separate card reader to download to a folder you create on your desktop. Once there, you can move them to iphoto.
Jan 05, 2010 | Canon PowerShot SD870 IS Digital Camera
I have a macbook and i connect the usb cable to upload my photos, but the usb is not recognized do i need to download any software. Its says that mac autmatically recognized the camara
the Mac normally recognizes the camera and launches iPhoto.
Try launching iPhoto, then plug in the usb cable. Make sure the connections are tight on the camera end of the cable.
Apr 22, 2009 | Fuji Finepix Z20fd Digital Camera
Lost the disk to my camera
Sir,
Click these links and download the software for free.
Link 1
Link 2
Link 3
Link 4
Link 5
Thanks Good Luck
Appreciate to rate as "Fixya"
Mar 11, 2009 | Kodak EasyShare C310 Digital Camera
Not uploading to Mac with USB cable
Sep 08, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Upload not working
try resetting preferences on the laptop (take a hard copy of any settings first), close it down, turn it over and remove the battery, then press the start button for 10 seconds, refit battery and re boot, all your settings will be reset and now try
Apr 14, 2007 | Sony Cyber-Shot DSC-P20 Digital Camera
Kodak EasyShare Z740 Digital Camera Logo
608 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
