RCA 32V420T 32" TV Logo
Posted on Aug 28, 2011
Picture is pushed down about 2-3" and left about
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Aug 28, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
0
Helped
583
Points
8
Tv normaly have the size of the screen in the menu so once u find it try all of them out and if none of them work get a new tv
1helpful
Keypad's 7&* not working
This picture repair guide may help to diagnose and repair on nokia X2 mobile phone handset.
Just follow the instructions stated on the picture itself.
Keypads key configuration by Rows and Columns
Row 0 = soft left, left, soft right, right
Row 1 = send, up, , down, camera
Row 2 = 1, 2, 3, select,
Row 3 = 4, 5, 6, volume up
Row 4 = 7, 8, 9, voume down
Row 5 = * , 0, #
Row 6 = music play, music forward, music rewind
Column 0 = soft left, send, 1, 4, 7, *, music play
Column 1 = left, up, 2, 5, 8, 0, music forward
Column 2 = soft right, 3, 6, 9, #, music rewind, camera
Column 3 = right, down, select, volume up, volume down,
tip
Levono ThinkPad Laptop Display Problem
If you have a Levono Thinkpad Laptop you may have a problem where the screen will either go blank or flicker after viewing a YouTube video. This happened on a new Levono Thinkpad E570 with WIN 10 I just received. I have experience with PC support before I retired and could not find a fix on the web for this specific problem. I finally traced the problem to the display adapter device driver. To fix the problem, you will have to first uninstall the current driver and let the laptop search automatically for the best current driver. The instructions to do this are below:
FIRST UNINSTALL CURRENT DRIVER BY:
1. Hold down the WINDOWS key (lower left on the keyboard) and push the "X" key.
2. From the pop-up menu select "DEVICE MANAGER"
3. From the list of drivers, select the one you want to change. In this example I am going to use "DISPLAY ADAPTER"
4. Double click on "DISPLAY ADAPTER"
5. Then double click on your current display adapter.
6. A window will pop-up with selectable tabs. Click on the DRIVER tab.
7. Click on "UNINSTALL DEVICE" and follow directions
8. Restart your computer when finished
9. Repeat the steps 1 to 4 above and you should see the display adapter driver should be the default windows driver, now you can close the device driver windows.
10. To automatically install a new updated driver follow the directions below.
TO AUTOMATICALLY INSTALL A NEW UPDATED DRIVER:
NOTE: You will need to be on-line to be able to search the web for the automatic updates.
5. Then double click on the current display adapter (Should now be the default Windows driver if you used the uninstall instructions above).
7. Click on "UPDATE DRIVER" and then select "Search automatically for updated driver software" and follow directions.
8. When complete you should have the new driver automatically installed.
Please let me know if the above instructions are helpful.
on Oct 26, 2017 • Miscellaneous
tip
Television factory resets
Factory Resets / modes
For all listed procedures, start with TV on, in TV mode, unless otherwise instructed. After procedure is complete, unplug set and re-plug in to finish reset.
If more than one procedure is listed for a given manufacturer, try the different ones until you see which one works for your set.
Coby:****************************************-
Enter menu, hi-lite "audio" then enter 8893
mode/source 2580 select "other setting",select "shipment" then yes, after it exits service menu you need to power set off.
Dynex ****************************************-
source/input 2580
hold vol down on tv and hold #1 button on remote, vol will jump to halfway and set shuts off. Turn back on have 1st time setup screen.
source/input 2580
menu 1999 (tv is on)
Element ****************************************
menu 0000
menu 1147
Haier ******************************************
pull up menu, hi-lite "audio" then enter 8893
Hisense *****************************************
In customer menu go to"Parental" enter 0000 then select"Clean All" then power the set off and back on and first time setup menu will be there.
For some models, same as above model except in menu it is labeled "Lock"
Insignia *****************************************-
input 2580 (tv is on)
Mitsubishi ****************************************
Menu 123 or menu 2470 (tv is on)
Panasonic
Hold vol- on TV, press and hold menu button on remote
Philips ******************************************
Push menu, select"Features"then select"current software info" push 062596-info on remote then push info again then red"initialize appears and changes color then complete. Push power button to exit
TV is on,push 062596-info on remote,then push info again, red"initialized"appears it turns green when completed, then push power button to exit
Polariod *****************************************-
Hold vol- and chan- or hold vol+ and chan+ (tv is on)
Proscan ******************************************
In customer menu go to setup,select parental control menu, enter 0000 then select "clear channel list".
RCA *******************************************-
Menu 1147
Sanyo *******************************************
hold vol down on TV, press and hold #1 button on remote, vol will jump to halfway and set shuts off. Turn back on have 1st time setup screen.
Samsung *****************************************-
Mute 182 power (tv is off)
(On some models, Factory Reset is on this menu, on some, you must go into the "Options" submenu
Seiki ********************************************-
Menu 0000
Sharp ********************************************
(Note - On Sharp models, you will need to look through the menus to find the reset option)
menu 1999
menu, 3481
menu 1147
while holding vol- & input buttons on tv plug in set when "k" appears push vol- & chan-
Sony *********************************************
Hold "arrow up" on remote and push power button on tv (tv is on)
Symphony *****************************************-
Source/input 2580
Toshiba ******************************************-
on Menu, select "Installation", then "System Information" press the right arrow button, ("System Information" will change to "Factory Reset" or something similar) follow on-screen instructions
Vision Quest ***************************************-
Source/input 2580
Vizio ********************************************
In customer menu under "Help" tab is Factory Default enter 0000
Vestel (most):
Menu 4725 then select "RESET"
Samsung (European):
Power off, Info - Menu - Mute - Power, then find factory reset and execute option.
LG/Zenith:
Hold MENU on TV and MENU on remote for 5~10 seconds, then select reset option.
NEC:
While powering on hold "MENU" or "INPUT" on TV, depending on model. (Only disables error lock out/buffer and puts TV in temporary service mode.)
To reset to factory, on remote, Off Timer - Menu - Exit - Off Timer, then select reset option.
Vizio Service Menu Method 1
1.Turn The TV off.
2.Press and hold the {CH +} & {CH -} buttons on the TV.
3.Then press and release the {POWER} button on the TV.
4.Release the {CH +} & {CH -} buttons.
5.Now press the {MENU} button on the remote.
6.You should get your regular menu up, but with a "F" in the bottom right corner of the menu (This is for factory).
7.Press and hold the {MENU} button for few seconds.
8.The Service Menu will be displayed.
Vizio Service Menu Method 2
1.Turn The TV off.
3.Then press and hold the {POWER} button on the TV.
4.Keep all three buttons pressed for few seconds.
Vizio Service Menu Method 3
1.Press and hold the {EXIT} button on the remote for 3 seconds then release it.
2.Then press the {1} {2} {3} buttons on the remote.
3.To exit, press the {EXIT} button.
GV42L FHDTV10A / JV50 / SV42 / SV320XVT / SV370XVT / SV420M / SV470M / SV420XVT1A / SV470XVT1A /
VECO320L1A / VO22L / VO32 / VO37 / VO47L / VOJ320 / VOJ370 / VP322 / VP42 HDTV20A / VP422 / VS420LF1A /
VU42 / VW32 / VW37 / VW42 / VX20 / VX32 / VX37 HDTV10A /VX42
Push "Menu" on remote and then push "Vol-" and "Input" on keypad
GV46 / P50HDM / P50HDTV10A
Press "Ch-" and "Ch+" buttons together once on keypad
GV42 / L42 / VP42HDTV10A / VP50 / VX37
Press and release "Menu" on keypad. Hold "Ch-" and "Ch+" buttons on keypad, then hold "Menu" on remote.
P42
Hold "Ch+" and "Ch-" along with "Power" on keypad. OSD will show "F" on right bottom portion of OSD.
VM60P
Press "Info" on remote, then press "Right Arrow," "Down Arrow," "Left Arrow," "Up Arrow," "Right Arrow."
The TV will show "Enter Factory Mode." Press "Menu" after message disappears and go do to "Setup."
GV47
Press "Menu" then press the following combination: "Info," "8," "2," "0," "6."
SV420M / SV470M / VF550M / VF550XVT1A / VF551XVT / VL260M / VL320M / VL420M / VL470M / VO320E /
VO320EP8 / VO370M / VO420E / VP504 / VP505
Press "Menu," and then press "2," "4," "8," "9."
VA19 / VA22LF / VA220E / VA26
Press "Menu" and then press the following combination: "0," "6," "2," "5," "9," "6"
VA320E / VA320M / VA370M / VT420M / VT470M
Press "Menu" and then press the following combination: "1," "9," "9," "1"
VW22 / VS370E
Press "Mute" once OR "-" twice (the dash next to the "0") and then press the following combination: "9," "8," "7," "6"
Main Page
on Apr 23, 2015 • Televison & Video
I have been unable to remove the wter filter. I have tried to turn it 1/4 of an inch clockwise as described in the owners manual but the filter won't budge. any suggestions?
OK maybe try 1/4 inch counterclockwise and pull down. Here is what the service manual quotes.
That is easy for anyone to misread.
Water Filter Removal
The water filter is located in the upper right-hand
corner of the refrigerator. The water filter filters water
for the ice maker and the water dispenser.
1. Turn the water filter 1/2 turn counterclockwise and
pull it down.
2. To install the filter, align the indication mark
(unlock position) and push it up while turning 1/2
turn clockwise until the lock position is aligned.
Do not over tighten.
That would be to the left while facing the filter and opposite for installation. Note where and when to push up. Please let me know if you have any questions and please rate if I am able to help you, Thanks, Sea Breeze
When I hit "return" page
1 is probably nthe default setting, push down on the slider and move it up and down a few times they do get dirty.
DickyO
tip
How to copy program using True Image
<p>Acronis True Image allows the computer to back up the data. The programs can periodically back up the entire hard disk, either online or in another physical disk. It can also backup individual items, such as files, folders or programs. <br /> <p><br /> <p>1. In a clear picture, click "File backup" from the main window. "The backup file is opened. <br /> <p><br /> <p>2. Navigate to the folder in the program with the left panel. For example, if you want the program to copy folder with the software Menezes "in" Program Files "directory, navigate to" Program Files ". <br /> <p><br /> <p>3. Folder from the right window. <br /> <p><br /> <p>4. Select the destination of the "target" drop-down box. For example, if you program to a "D" of the secondary unit. <br /> <p><br /> <p>5. "Backup Now" button. <br />
on Jun 22, 2011 • Computers & Internet
1helpful
Hi,im looking for valve clearance specs for the kawaski 23hp fh680v-8s10 motor ??
The adjustment is .003 - .005. You must hold the rocker arm by lifting up on the valve depressing side and pressing down on the push-rod side while making the adjustment. Any other means of adjustment and it will be incorrect.
Below is quoted from the service manual without pictures
(FixYa Note TORQUE on lock screws is 61 inch pounds)
Valve Clearance Inspection
NOTE
?? Valve clearance must be checked when the engine is cold (at room
temperature).
• Remove the rocker cover (see Cylinder Head Removal).
• Place the piston at top dead center (TDC) of the compression stroke
turning the crankshaft clockwise facing the flywheel.
No.1 Cylinder:
?? The left projection [A] on the flywheel is faced with the right leg [B]
on the #1 ignition coil [C] as shown.
?? Check the intake and exhaust valves are closed completely, if not turn
the flywheel one turn (360??) clockwise and face the left projection with
the right leg again.
No.2 Cylinder:
on the #2 ignition coil [C] as shown. Follow No.1 Cylinder alignment.
• Then check the valve clearance.
?? Using a thickness gauge [A], measure the valve clearance between
the rocker arm [B] and the valve stem end.
If the valve clearance is incorrect, adjust it.
Valve Clearance (when cold)
Intake, Exhaust 0.075 0.125 mm (0.003 0.005 in.)
Thanks for using FixYa.
Kelly
May 18, 2010 • Garden
12helpful
Trying to change the cabin air filter
1. Open glove box
2. Unhook elastic retainer on right side
3. Locate the two "stop tabs", one on the upper left and the other on the right side. Push both to the left to clear their stops and the glove box will swing down, allowing access to the filter cover.
9helpful
3answers
Philip PET 702/98 Poratable
On remote push "Setup", use arrows to find out page "Preferences", enter 9653 and change region code to 0.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
