SOURCE: won't power up
Hi, The owners manual says that if the red light is flashing, it is an indicator that it is ready to be turned on (use remote or onboard on button); flashing red & green - too high temperature inside, the unit is overheated. Check and clean the air filters; If the red light is steady, abnormal condition and you have to call for service. A copy of your manual is available at http://www.eiki.com/resources/resourcedownload.ashx?filename=/ownersmanuals/om_xb25_20_sb20.pdf Hope this be of some help. Pls post again how things turn up. good luck and kind regards.
SOURCE: Eiki LC-X1100 Powers "off" after 10-15 minutes
even if the filters are clean, you will still need to blow the dust out of it with canned air. may be overheating. otherwise, sorry to say, it is the ballast.
