Question about ASUS K8V-MX Motherboard
K8v-mx moterboard sata not detecte bios and windows
Posted by soyabrana on
Hans Pedersen
  • ASUS Master
  • 3,606 Answers
Hi, you can download a manual here:
http://support.asus.com/Download.aspx?SLanguage=en&m=k8v-mx&p=1&os=
Please select your operating system.
Select manual and click on global for download.
Unzip the file before you can read it.
Its maybe just a setting in the bios that makes the fault.
Posted on Aug 28, 2011
K8V SE Deluxe board. B.I.O.S. Main on Auto, No Hard Drive Detected. Hard Drive is shown in Boot and RAID. Have checked all cables and tried a different HD. Cannot load O.S. from disc. Fails because...
I think u have to download the driver for SATA drive!
Read again ur owners manual and download the driver and procedure so that the bios can detect the SATA HD!
Jun 13, 2011 | ASUS K8V-MX Motherboard
MY BIOS IS NOT DETECTING SATA hard disk, i system is not detecting SATA hard disk
When the system is booting go into the bios settings. The option for sata drive detection may need to be turned on there, once verifying that option is on save & reboot the pc and it should detect the sata drive.
Mar 14, 2011 | ASUS K8V-MX Motherboard
ASUS K8V-MX Motherboard recognizing 320 GB SATA harddisk. Why?
It could be that your BIOS needs updating for this motherboard. Take note of your BIOS version when your computing is booting. Try hitting the Pause key to freexe the screen, but if no luck go into BIOS and see if the BIOS version is listed. You typically get in BIOS by hitting the "Delete' key on your keyboard when the computer starts up and the first bunch of words appear in white characters (might be a light grey)
Go here:
http://usa.asus.com/product.aspx?P_ID=dJ2XP7zr8tzeYbLp&content=download
Latest BIOS (note its a beta version ie not formally released) is
K8V-MX Beta BIOS 0501
Latest beta BIOS.
Feb 17, 2010 | ASUS K8V-MX Motherboard
HELP ABOUT K8C-X motherboard
Hi thun, Unplug the power cable from the PC.
Please reset the bios. This is shown in you're user manual on page 1-17. (If you no longer have you're user manual for the Asus K8V-MX MB you can download it from Asus by clicking on this link):
http://support.asus.com/download/download.aspx?modelname=K8V-MX&SLanguage=en-us
Remove the SATA data cable & clean both ends of the cable with a few drops of alcohol on to a cotton swab. Than clean both SATA ports on the motherboard using the same method.
Also clean the SATA power connectors in the same fashion. (Allow time for the alcohol to dry).
You can help it dry using some canned air.
Re-connect the SATA data cable & SATA power cable to the SATA drive. (Check all other connections within the PC for good connections before closing case). (SATA data & power connectors are easily knocked loose, so be careful).
Plug the power cord back into the PC & boot the PC. Enter you're bios. Check the main menu & make sure the bios has listed the SATA drive. Than go to Boot menu. Page 2-27, 2-28 in the manual. Make sure you see the SATA drive listed here. If you are sure the SATA drive was listed in the main menu than it must also be listed in the Boot menu.
If it is not listed in the Boot menu than there is a problem with you're bios. You're board is warranted for three years from manufactures date. Please call Asus tech at 1-812-282-2787.
M-F 9:00AM to 5:00PM EST. You will need the serial number printed on a white label located on the pink LPT port. You can see this only from within the PC. Asus will ask for that S/N to determine if you're board is still within warranty. If it is, make sure you get a case number & instruction before ending the call.
Good Luck!
Mike
Jun 06, 2008 | ASUS K8V-MX Motherboard
K8V-MX SATA and XP instal problem
enter the bios and disable raid function, there is no specific SATA drivers unless you work with xp SP1.
In the following link you can read the user's manual : http://dlsvr03.asus.com/pub/ASUS/mb/sock754/K8V-MX/E2335_K8V-MX_h.pdf
May 04, 2008 | ASUS K8V-MX Motherboard
SATA drive not detected in BIOS and windows does not boot up
i have same problem with WD 250GB sata HDD. with same bord K8V-MX,  i all reday update BIOS with 0502 version.
plz plz plz help me.
CC me [email protected]
Feb 21, 2008 | ASUS K8V-MX Motherboard
Sata driver
check for the website of your HDD vendor.eg-www.seagate.com for seagate hdd.
make sure you format using fat32 file system.
Jan 28, 2008 | ASUS K8V-MX Motherboard
Sata DVD Ausus using K8V-MX
TRy to load the "optimized bios default setting" in your bios setup. If not solve the problem maybe in your windows issue.
try to boot up windows in safe mode and then start it normally and let the windows fixed the problem on it.
if still problem exist maybe you need to repair your windows installation using the new SATA DVD to resolve problem regarding the issue. or reinstall it. (Note: important files was no guarantee to retain, backup files when doing this).
note:
Jan 06, 2008 | ASUS K8V-MX Motherboard
ASUS K8V-MX Motherboard Logo
Top ASUS Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Roy May
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
