Make sure the red wire and yellow wire have 12 volts (may be as high as 14.4 volts) positive voltage & the black wire is grounded (negative) Also check the fuses on the head unit (usually on the harness) and make sure the speaker connections are not shorted before powering it up. Any blue wires from the radio should be isolated & taped off to prevent shorting. Those are used for power antennas & amplifier trigger.
