1.Connect the iPad to the computer and launch iTunes.
2.Click on the iPad name on the left side under devices.
3.Click on the Photos Tab on the right.
4.Uncheck all of the albums or folders that you want to remove from the iPad under the Sync Photos from heading.
5.If you want to remove all of the photos - uncheck the Sync Photos From heading
6.Click on Apply in the lower right corner of iTunes
More info: How to delete a photo on an iPad
As long as the photo has been taken on the ipad and is on the camera roll, select the picture you want to delete and at the bottom right hand side of the ipad screen there will be a trash can icon. Click on the trash can and you will be asked as to whether you want to delete the picture or cancel, choose delete.
Failing that if the picture is in the photo library when you connect the ipod to your computer open itunes and click on your ipod under devices and then on the photos tab at the top of the window and change the pictures you want to synch with your ipod.
Hope this helps.
The Kernel Recovery for iPod software enables users to recover all files from iPod devices even if the iPod is damaged or broken, including mp3 files, images, video files, and all other data. It can also recover accidentally or intentionally deleted files from the device. Know more detail visit http://www.ipodmusicrecovery.org/ iPod Music Recovery
This way should fix the issue about how to delete a photo on an iPad.
1. Navigate to the folder on your computer that contains the photos you want to delete when you sync with your iPad.
2. Delete the photos you no longer want to sync with your device or move them out of the folder to somewhere else on your computer.
3. Connect your iPad to your computer and then open iTunes.
4. Click the name of your iPad under Devices.
5. Click "Sync" in the lower right corner of the program window to sync your iPad with your iTunes account. After the sync is complete, the photos you removed from the folder you're syncing with your iPad are gone from the iPad.
SOURCE: How to delete photos from the Ipad
If to have the iPad before the camera was added, you have the original iPad. If you synced the photos from your computer, you have to delete the photos by syncing with iTunes again, but you have to "uncheck" the albums or folders that you want to remove.
4.Uncheck all of the albums or folders that you want to delete from the iPad under the Sync Photos from heading.
5.If you want to delete all of the photos - uncheck the Sync Photos From heading
Done.
If it can't work, you can refer to the article about Delete photos from iPad.
Good Luck!
