Question about Ovens
HI,
This issue is the oven got too hot during self clean. There is a thermo-fuse to the display on the right hand side directly to the board. But this fuse does not show up in the wiring diagram. Also you have have taken out a second thermo fuse on the backwall to the oven in which it must be removed from the cabinet to replace. I need a model number to direct you on the correct parts, and location of this parts.
Get back to me with more information..
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Posted on Aug 28, 2011
Jun 28, 2014 | Frigidaire FEB24S2AS / FEB24S2AB Electric...
Feb 06, 2008 | Ovens
Jun 05, 2017 | Whirlpool RBS305PD Electric Single Oven
Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Nov 12, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Nov 22, 2011 | Fisher and Paykel AeroTech Double - OD302M...
Hi
This means a
loose/broken wire on the oven temp sensor or the oven temp. sensor itself is
bad and should be replaced. To solve this issue test the oven temp. sensor, it
should read between 1080-1120 ohms, if the rating is more then that and the
door appears to be closing fine then it is the control board that is bad and
should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 29, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
May 19, 2010 | Whirlpool RBS245PDS Electric Single Oven
Nov 26, 2009 | KitchenAid KEBS177 Electric Single Oven
Aug 31, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Apr 21, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
90 people viewed this question
