Computers & Internet Logo
Posted on Aug 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
UBUNTU 11 Installation Error - Mount Problem after upgrade from UBUNTU 10 to 11
  • thecooldewd Aug 28, 2011
    UBUNTU 11 is not installed completely and has corrupted files. It takes me to shell mode and I do not have access to any physical computer or monitor etc. It's a dedicated server. I am unable to wget while in Shell mode. I upgraded from UBUNTU 10 to 11 which has caused this. I can only access my server via KVM.
    any advises?
Anonymous
Level 3:
  • Master 670 Answers
  • Posted on Aug 28, 2011
Anonymous
Master
Level 3:
Answers
670
Questions
0
Helped
159407
Points
1915
First guess is that there is an incorrect entry in /etc/fstab. Another possibility (hope not) is that something is wrong with one or more partitions or the drive / controller.
Suggestions:
-boot from liveCD/liveUSB and check integrity of partitions (using gparted for example)
-mount your root partition and take a look at /etc/fstab for anything wrong (you might try using /dev/sd? instead of UUID?)
-worst case scenario, there is a repair install option from the liveCD/liveUSB
You should restart the update manager again. There was an update that was justed released for that not to long ago.
Hope this helps!
Arjun Komath
Level 3:
  • Master 1,170 Answers
Arjun Komath
Master
Level 3:
Answers
1170
Questions
8
Helped
439565
Points
3355
As you said about the error, its an error usually comes due to the file missing.
TO avoid that please download from below link. All the necessary details are added there.
So download from here.Read carefully instructions. http://www.ubuntu.com/testing/natty/beta
i hope it helps.
Thanks
Unable to upgrade it to Window-10 for Gateway DX4885. It throws an error while installing the update
Copy and paste the following link into your web browser:
https://www.alphr.com/upgrade-windows-8-1-to-windows-10/
Windows 8 is 'old hat' now and you may have difficulty in upgrading, if it is actually still possible.
Your computer is old? There's (old) 32 bit computers and more modern 64 bit computers. An operating system is designed for either 32 bit or 64 bit.
What you can try is another OS such as Linux. Run it as a 'live version' to see if you like it before you install/use it. All you need is a usb drive or dvd that can be written to.
1. Download rufus
https://rufus.en.lo4d.com/windows
2. Download a Linux iso image - such as Desktop Ubuntu (it will download into the downloads folder)
https://ubuntu.com/#download
3. Insert the USB drive into your computer
4.Open rufus - navigate to the download folder and install Ubuntu onto the USB drive. (simply copying and pasting the files will NOT work. You have to make a bootable USB. Rufus does this for you.
You now have a portable OS on a USB.
5. Restart your PC and open the bios settings. Navigate to the boot sequence and change the first boot device to USB. Press F10 and exit. Your PC will then restart and run Linux from the USB. No changes are made to your computer.
You can either run Linux 'live' from USB or click on the desktop icon which says install onto computer.
If you wish - instead of putting Linux Ubuntu onto USB you can burn the downloaded .iso file onto dvd and choose cd/dvd drive as first boot device.
Again, simply copying and pasting the Linux image onto dvd will not work. You must make it bootable. I you don't have the software try installing k3b:
https://sourceforge.net/projects/k3b/
It's all actually quite easy to do.
2answers
How Can I Fix Error Code 80240020 in Windows 10?
Hello
Steps to repair error 80240020 while installing Windows 10 free upgrade
Step 1: Very firstly go to $Windows.~BT folder in C: and make sure that all the Hidden items option is checked in the window toolbar section. And try to remove almost all the files and folders. It may also happen that some of the files you are not able to delete as because of the permission issue.
Step 2: Now delete the entire things in the C: > Windows > Software Distribution > Download folder.
Step 3: Then execute the command prompt as an administrator and look for 'cmd' from the starts menu or screen and click right on it and select the 'Run as Administrator' from the context menu.
Step 4: Type the command "wuauclt.exe /updatenow" and hit the enter button.
Step 5: Wait for couple of minutes and then verify for presented updates eg. Windows update. The downloaded Windows 10 start automatically with the actual downloaded size, it mainly depends on the current installed version on your PC.
Step 6: As the downloading finished, 'Preparing for Installation' will start after that you can attempt to install the update again.
Step 7: You are able to see the message prompt "Upgrade to Windows 10 is ready". You need to just press the Restart Now or Start the upgrade now button on the screen
Step 8: And now your PC restart and the Windows 10 installation begins automatically. The process is comprised of three phases:
  1. Copying files
  2. Installing features and drivers
  3. Configuring settings
Step 9: Let the PC to reboot for pair of times during the installation and for this you need to wait for 10-15 minutes for finishing, it depend on the size of the file and also the speed of the PC
Step 10: As the installation is completed, a welcome screen will prompt and then you need to follow the on-screen instruction to enter the login screen
Step 11: Lastly type your username and password for booting into the newly installed and configured Windows 10 desktop. How To Fix the 80240020 Windows 10 Installation Error
Should I backup all my files prior to installation priort to upgrading to Ubuntu 14.04 lts?
upgrade do not alter your system files/folders. In case you are installing the new version rather than upgrade, then there is a chance you may loose your files in case you format your hard drive.
Linksys Wireless WPC54G drivers for ubuntu (Linux)
Just re-installed Ubuntu and let the installation load the broadcom b43 driver. If it doesnt the firmware need to be updated.
Here is a step by step install and firmware update for the b43 as well .
http://www.itadmintools.com/2011/11/getting-your-linksys-wireless-adapter.html
After installing ubuntu i get a blank screen saying error
I think, this problem happened because you are installing Ubuntu from the ISO image on your physical hard drive.
Here is the way around this problem. when you get to the option to unstall Ubuntu, press F4 and choose Safe graphics mode. then choose the first option on the menu:Try Ubuntu without any change to your computer.
If you still get the same problem do this:
At the prompt, press F4 and select "Safe graphics mode".
then press F6.
Modify the following boot line:
"Boot Options seed/ubuntu.seed boot=casper initrd=/casper/initrd.gz quiet splash -" Delete the part that says "quiet splash "" -" and replace it with "vga=791 noreplace-paravirt"
That will make Ubuntu boot onto the GUI. After logging into Ubuntu Interface you should be able to see an installation folder on the desktop:
Click on the Install folder. The installation wizard should come up:
Select the language and click Forward. Next Choose your location:
Choose your city, and click Forward. Don't worry if the time zone is not OK, you can change that later when you login to Ubuntu.
Next, you will need to choose your Keyboard layout, if you are in the US, mostly all your options will be the default. If you are not in the US, choose your settings accordingly. Click Forward.
Next, you will need to prepare the disk space, remember that you chose to use 10 GB of hard disk space for this virtual machine, so select the default option, Guided "" use the entire disk.
Click Forward. Next, you will have fill out, your name, your username, password, and Computer name":
After you have entered the info, click on Forward. Next, you will get a summary of the installation. Click Install to begin the installation:
The installation should start.
After 20 "" 30 minutes, the installation will finished, and will ask you if you want to reboot. At this stage Ubuntu is installed on your computer permanently.
Click on Restart now. Now Ubuntu should be installed and ready to be used on your virtual PC
1helpful
3answers
Hya i want to run ubuntu 10-04 can any one help
Run or install??, on what type of PC???, from what media to what kind of media???, usually you download the .ISO file from the UBUNTU web site, burn it to a CD or DVD (the version suitable for your type of PC) than you BOOT the PC with the LIVE CD you created, and VOILA! UBUNTU is RUNNING... Don't forget grate power comes with grate responsibilities...
1helpful
3answers
I have an ASUS netbook that runs linux. I don't know linux, but was told to upgrade to ubuntu. I don't know how. Anyone know how?
1. I would suggest finding out which model Eee PC you are using and the hard drive size & type (4GB SSD, 160GB SATA, etc...). If you have less than 4GB, I would probably recommend using another Linux distro, as the Netbook Edition of Ubuntu is pretty heavy.
2. Next, I would probably suggest plugging in the Eee PC (Software/OS installation is very power intensive).
3. Download your distribution (Ubuntu Netbook Edition or Desktop, etc).
4. Download a copy of unetbootin for your PC (unetbootin.sourceforge.net -- There are Linux & Windows versions available.)
5. Using a USB thumb drive (USB Memory stick), you will want to wipe the drive (format using FAT/FAT32 filesystem).
6. Run Unetbootin, selecting the proper USB thumb drive & ISO image from the Ubuntu website.
7. After Unetbootin is finished, close it and safely disconnect the USB drive.
8. Next, plug the USB thumb drive into the Eee PC.
9. Turn on power to the Eee PC & after seeing the initial BIOS splash, hit the ESC key on the keyboard. This should bring up a boot selection screen. Using the arrow keys, select the appropriate USB drive and hit Enter (Return).
10. If all goes well, you should be running Ubuntu Desktop/Ubuntu Netbook Edition as a live desktop. (The installer is a link on the desktop.)
11. There are several step-by-step guides out there, so check them out, if needed. The installer should be very simple on this type of hardware, etc.
Good Luck!
--TaoBeastie
1helpful
Gurb hangs after installing ubuntu on raid 0. I left a 500 Mb /Boot (marked as bootable), 1,7 Gb swap on each disk and /root and /home partitions on raid 0 disks each. Installation gave me no problems but...
I too upgraded from Ubuntu 9.04 to Ubuntu 9.10 using wubi, the Windows ubuntu installer. Everything was fine, and I even admired the beautiful desktop, added KDE. I was very impressed until came the time to reboot. Grub hung. I entered the console and tried to repair: To no avail.
I reinstalled Ubuntu/Gnome without installing KDE. All went fine until the time to reboot. It hung again. After several trials, I decided to go back to Ubuntu 9.04.
From what I could gather on the Internet, it has to do with the new type of file system ext4. If only I had the choice to use it or not.
Since I was using wubi and was not offered the choice to install the ext4 file system, I do not know whether that choice is offered on a full scale installation without wubi. You might try to find out if you can customize the installation process and not select the ext4 file system, if possible.
One remark concerning the amount of swap space you are setting aside. In my opinion that's too much: I have a 2GB RAM, about 300MB swap space, and each time I monitor swap usage I find it very low to nil.
Concerning Ubuntu 9.10, I will wait until the bug(?) is fixed before upgrading. Good luck to you
I hope it helps
Thank you for using FixYa.
16helpful
4answers
What is grub error 17? how to fix it?
Its GRand Unified Bootloader used in Linux OS.
Normally you get this error when GRUB is not able recognise the partition from which you are trying to boot the system. Make sure the boot partition on your system is recognisable by GRUB (such as EXT3).
You can try to restore the GRUB using the LIVE CD
  1. Boot From Live CD
  2. Open Terminal Window
  3. type >sudo grub
  4. then type : find /boot/grub/stage1
  5. you'll get something like: (hd0, 1)
  6. then type : >root (hd0, 1)
  7. type: > setup (hd0)
  8. >quit
  9. >exit
Remove the Live CD and reboot the system.
Please let me know if you need any further assistance.
Thank you for choosing Fixya
Upgrade Ubuntu Error
-While booting your grub bootloader, press "e", enter the edit mode.
-Press "e" on the first line.
-(hd0,0) Change the last 0 to a 2, so it reads: (hd0,2).
-Press ‘b’ to boot.
Good luck.
Grand Canyon Tech
Grand Canyon Tech
