George Foreman GR35TMRCB Indoor Grill Logo
Posted on Aug 28, 2011
Our grill wont heat up it was working earlier today but it just isnt working now
My grill uses the same elemant as my grill but grill wont work , but oven will
when you use your grill the oven door must be open if if does not heat then the door switch is faulty
Apr 21, 2012 • Ovens
2answers
Creda Europa Oven an Grill Big oven has Stopped working what would be possible causes
do you mean there isnt any power going to it or it dosent heat up or it just gets warm more detail please
Facebook isnt working on my computer.
delete cache and temp files .. uninstall any toolbars on the internet explorers that should fix it
1helpful
Teka h e 500 oven wont heat up....
If the fan is working o/k then the oven element is probably faulty, this should be at the rear of the oven behind a removeabkle cover.
Make sure you have the control set to grill , for grilling
Dec 03, 2009 • Ovens
Weber gas grill wont heat past 300 degrees
are the fire red , orange or blue?
must likely is the burner control.
check the air control at the back of the burner control, it should be open all the way.
it it is, then try another themostate.
WONT HEAT
I AM LOOKING FOR A SOLUTION I DON'T HAVE ONE
Red Light
Are you pressing and holding the button and does the system still power on and off alright? If the system still works properly then it isnt a huge concern. If it wont power on or off then do an exchange at Wal-Mart.
Top George Foreman Kitchen Appliances - Others Experts
ZJ Limited
ZJ Limited
john h
ADMIN Andrew
ADMIN Andrew
Are you a George Foreman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
