Question about Dewalt Heavy - Duty 5" Vs Random Orbit Sander Kit - D26453K
Can I use sanding disks with no holes on a D26453K orbit sander?
Posted by coma360 on
David Ford
  • 2,176 Answers
Yes as long as it is the same type of disc, e.g. hook and loop or psa.
Posted on Aug 28, 2011
Why is my 5" sanding disks not sticking to my sander?
The holes are to suction dust for a vacuum attachment or dust collection bag. The sander will have a very smooth pad almost shiny if it takes stick-on discs (PSA). If not it will be a velcro pad and in that case you need the velcro discs. This description sounds like you have a velcro pad. Sticky discs wont stick to a velcro pad.
Apr 24, 2016 | Sander Tools & Hardware - Others
Where can i obtain a sanding pad for a ryobi HRS115K Orbit sander
The 4 1/2" 8 vac hole Hook & Loop back-up pads for the Ryobi Sander are no longer available, But you can apply a new hook surface to your present pad $3.75 each conversion disc at Supergrit abrasives , Gettysburg, PA 800 822-4003
Jul 03, 2014 | Tools & Hardware - Others
Cant figure out how to install the sanding disc's
This info may help;
Features: DeWalt D26451K 5" Random Orbit Sander Kit
  • 3.0 Amp motor operates at 12,000 opm providing ideal sanding speed for smooth finish
  • Textured anti-slip top & body grip provides ultimate comfort and control during prolonged use
  • Controlled Finishing System maintains pad speed and minimizes gouging during start up
  • Dust-sealed switch prevents contamination
  • Sealed 100 percent ball-bearing construction provides longer life
  • High capacity dust bag with built in vacuum adapter provides maximum dust collection with or without vacuum
  • Dual-plane counter-balanced fan reduces user fatigue
  • Accepts 5", 8-hole hook & loop paper allows sanding discs to be switched back and forth quickly and easily
  • The sanding discs mate to the sander plate similar to Velcro, and this particular sander uses a 5" disc with 8 holes in it. Can be purchased in Home Depot, Lowes, etc....
Hope this helps!
Jul 23, 2009 | Dewalt d26451k 5" random orbit sander kit...
Orbital sander doesnt orbit!
Never start the Sander without first placing it against the surface to be sanded. In free air the Sander will not osolate.
Jun 12, 2009 | Makita BO5010 5" Random Orbit Sander
My 5 inch random orbital Sander: the self stick sanding disk will not stay on it. Can you tell me the trick to making them stay on sander? Thank you!
If your disks have a "furry" bottom you have to have something like velco stuck on the base of the sander. The velco is slf sticking and you get it at the hardware store. Good luck.
Jun 10, 2009 | Makita Tools & Hardware - Others
Bosch 3107DVAS Random Orbital Sander not working.
You must replace the fan assembly. The part number is
2606610901
Hope this helps
May 04, 2009 | Bosch 3107DVS Electric Sanders & Polishers
How to remove round sander for iron shaped one
You need to remove the allen head cap screw in the center of the base, then remove the washer, and pull the base straight down off the sander. If you can't get it to pull off, try gently rocking it a little as you exert pressure to pull it off.
Random orbit sanding base
With this sanding base, you can use the tool as a random orbit sander.
Fitting and removing the sanding base (fig. B)
- Place the sanding base (3) onto the spindle (10).
- Place the washer (7) onto the spindle.
- Insert the Allen screw (8) into the screw hole in the spindle.
- Tighten the Allen screw using the Allen key (9) supplied.
- To remove the sanding base, remove the Allen screw (8) and washer (7).
Fitting sanding sheets (fig. C)
- Hold the tool with the sanding base (3) facing upwards.
- Place the sanding sheet (11) onto the sanding base (3). The holes in the sheet do not need
to line up with the holes in the base.
Large detail sanding base
With this sanding base, you can use the tool as a detail sander or an orbital sander.
Fitting and removing the sanding base (fig. D & E)
For detail sanding, the pointed end should face forward as in fig. D. For sanding large areas,
the pointed end should face to the back as in fig. E.
- Place the sanding base (12) onto the spindle (10). Make sure that the legs of the base
locate into the tool.
You can also view the factory manual here: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/479727-00,MS1000%20SANDER.pdf
Be patient, and good luck! Let me know if this doesn't solve your problem and you still need help!
Mar 08, 2009 | Black & Decker Black And Decker Cyclone 4...
Dewalt Heavy - Duty 5" Vs Random Orbit Sander Kit - D26453K Logo
134 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
efs_perpends
efs_perpends
john h
Tim Venetis
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
