Question about Canon PowerShot A495 Digital Camera
My canon PowerShot A495 was down to its last battery bar last night. I wanted to see the pictures I took so I switched it on. It did turned on and the lens opened like it supposed to but the camera suddenly turned off. I thought maybe the battery doesn't have enough charge to keep it open. With the lens sticking out, I popped in new batteries and now a "Lens error, will be sut down automatically, restart your camera" message appears in the screen. Help me! I don't know what to do!
  • 6,831 Answers
Hello
Thank you for using FIXYA!!!
This is a suggestion. If you do not feel comfortable trying it, you will need to take the unit to your nearest service centre. Feel free to let me know if you need any assistance.
The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Oct 13, 2011
6ya staff
SOURCE:
Why won't my Powershot A495 take a photo?
iIt seems that the battery is low or not powerful enough to run the camera properly. when the camera notices there is not enough power it will automatically shut down. ensure the battery is fully charged up on the charger and then try it. the battery type is
Canon NB-3L and if the camera is a few years old or has been stored for a long time the battery may need to be replaced.
if all these have been done and still the problem persists i would recommend a dealer have a look at the camera.
to replace battery open slider plate on bottom of camera and flip tab to release the battery pack.
I hope this was useful.
May 28, 2014 | Canon PowerShot A495 Digital Camera
How to unlock my memory card of Canon PowerShot A495 Digital Camera
Take your memory card out of the camera and switch the position of the "lock" tab. One position is for "locked" (i.e., "Write Protected") and the other position will allow the card to be written to (unlocked). Some cameras have image protection built into the on-camera software and you may need to configure this there.
Jan 06, 2012 | Canon PowerShot A495 Digital Camera
Canon Powershot A495 Wont power on using the ON/OFF button
Try this: remove the batteries and memory card....press every button...leave it alone for 20 minutes...insert the battery and then the card....turn it on.
Nov 08, 2011 | Canon PowerShot A495 Digital Camera
My canon powershot a495 has a problem. it always
Alkaline batteries just don't have the power for more than a few pictures in today's power hungry digital cameras. Some batteries may also have reached their shelf life at the store, and though brand-new right out of the package may even have problems just powering startup of the camera. The one's that came with your camera are just to show you that the camera works, but as you've discovered, they'll only last for a few pictures. Digital cameras that use AA's for the most part should only be used with modern rechargeable batteries. If you read the camera's instruction manual concerning batteries, you should see the same recommendation.
Modern rechargeable batteries have over 5 times the power density of alkaline batteries (that's right, they last up to 5 times longer than an alkaline battery. And you can recharge them over and over!). Keep in mind rechargeable batteries will save you much money in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may be angry with yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Jul 04, 2011 | Canon PowerShot A495 Digital Camera
On my canon powershot A495 my camera says lens error restart camera but i havent mistreated it how can i fix this myself
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 12, 2011 | Canon PowerShot A495 Digital Camera
My canon powershot a495 has a problem. it always shows low battery and turns off. i have changed to new batteries three times but the same problem. i bought 3 months ago. help please thanks
my canon powershot a495 has a problem.
Apr 18, 2011 | Canon PowerShot A495 Digital Camera
Batteries do not last...using alkalineAA Energizer
That would be expected for alkaline batteries, especially if you are using flash. Try lithium batteries, or even NiMH rechargeable batteries-- those will be significantly better.
Mar 06, 2011 | Canon PowerShot A495 Digital Camera
I have a canon power shot A495 digital camera. problem with camera is new or fully charged batteries discharges after taking 4 to 5 photos when taken with flash
all the canon cameras batteries do not last more than 2 years.
the best would be to purchase a new battery which you can find at any Target, OfficeMax of a sort department stores.
Oct 11, 2010 | Canon PowerShot A495 Digital Camera
My camera screen is black.
If the new pictures are all black, then the problem is not on the LCD display, but it is a faulty CCD sensor.
The CCD image sensor is the device that captures the picture .
CCD sensor is covered even after warranty, contact canon ringing the phone number listed on the owner manual.
Mar 28, 2009 | Canon PowerShot SD800 IS / IXUS 850 IS...
Canon PowerShot A510
Your LCD display might have switch off by mistake.
Press on the display button in the camera.
Jun 09, 2008 | Canon PowerShot A510 Digital Camera
Canon PowerShot A495 Digital Camera Logo
46 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Ekse
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
