Cavalry Storage Cavalry CAUO37500 500GB OneTouch Ext USB 500 GB USB 2.0 Hard Drive Logo
Question about Cavalry Storage Cavalry CAUO37500 500GB OneTouch Ext USB 500 GB USB 2.0 Hard Drive
I have a cavalry 500 gig external harddrive, and it works FINE , untill i try to move i big file onto it, small files are never a problem . is there a reason for that or a way to remidy that?
Posted by danny_revolv on
5 Related Answers
Anonymous
  • 13 Answers
SOURCE: PC stopped reading Cavalry External HardDrive
i have a feeling its not the hard drive thats bad i think it sounds like the case .
you can try buying another case and transfering the hard drive to it the case is around $20.00
Posted on Dec 05, 2007
Anonymous
SOURCE: Seagate 500 Gig External Drive disappeared !
external harddrive turn them selves off after 5 minutes if it isn't being used.
Posted on Aug 07, 2008
Anonymous
SOURCE: Cavalry 3.5 External Storage
Found manufacturer.
Posted on Sep 18, 2008
Anonymous
  • 4 Answers
SOURCE: External hard drive unreadable
Just a thought-
Make sure all your connections are hooked up before turning anything on. Turn on the external drive BEFORE turning on your computer.
Posted on Feb 08, 2009
Anonymous
  • 103 Answers
SOURCE: lacie 500 gig external hard drive
Yikes 500 GB is a lot of data to lose, especially if you have no back-ups. In case you have never seen the inside of one, a hard drive is a series of metallic/magnetized platters on a spindle and a series of arms (resembling those of a record player) for each platter which record and retrieve data in the storage sectors formatted on the drive platters. The top 3 enemies of hard drives are: Impacts - Heat - Magnetic Objects . . . these top 3 all prove fatal to your drives operation. I am guessing the impact from when you dropped your HDD jarred the arms from their position or even may have broken the reader head. The bigger the storage of the drive, the more fragile they seem to be. Once an arm is dislodged or broken, the drive cannot function... the damage is mechanical. An arm knocked from its point of origin when not in use or jarred durring data access can no longer properly know where data is or fins its original position. Dont waste time on file recovery programs if this is the case, they require an operational drive to scan leftover data. . if the damage is to one of the platters, you might have luck with a software recovery application, but the process is very very slow and will take days. You can try taking it to data recovery experts and it will cost you usually around $1.00-5.00 per gigabyte - pretty costly. My advice, See if you can RMA the drive if it was under warranty) to get a new drive . . . or even have the data retrieved if it was that important . . . other than that, move on and be more careful with external drives in the future. Look for drives that have good impact ratings if you have a propensity for clumsiness, even then, handle with care.
Posted on Mar 27, 2010
Testimonial: "thanks for the advice very helpfull"
My computer accesses the file on the external hard drive, starts to download the information, then my computer freezes. The only way to get out is to power down, holding the computer button down till it...
maybe the file is corrupt or has a virus. Do full virus scan on freshly rebooted computer. try starting the PC in safe mode (F8 when booting) and open the file. do other files of the same type open up ok?
1helpful
I recently purchased a new Cavalry external hard drive (500gb, CAUG25500), and had been using it on my Thinkpad laptop with XP. It was working fine, no problems. Before a trip I was going on, I wanted to...
1. This could be due to several things.
a. The power supply for the external drive is not working properly
b. A broken power supply connector.
c. The USB drive was disconnected improperly > that is not disconnected safely in Windows
d. The external drive controller in the USB case is defective. A new case is needed.
External hard drive will not power on
The adapter case could be faulty but the hard drive may be OK.
Remove the hard drive and connect it to an USB hard drive adapter. Then plug the adapter into a working computer's USB port and if this computer sees it as an external hard drive and you can open the folders and files, then the hard drive is OK and you only need to buy a new USB hard drive adapter case.
If the hard drive is faulty, and the data is very important to you, there are companies that can retrieve data from faulty hard drives BUT it will cost you an arm and a leg for their services.
USB not reading in computer
try a new cable, and a different usb hub or a different pc, if not found, drive is bad
2answers
Seagate free agent pro 500 gig external hard drive NOT RECOGNIZED
You better check with the Seagate people. This seems to be a problem with the casing. And since you're under warranty, you can get a replacement.
Just a thought-
2answers
External hard drive disk space
Hi
Is it showing the 300gig in the properties? if yes then try to copy with command mode,If again its given problem then u need to backup your data and format the drive, then try copying.I think it will work.
T.Boopathy
Lacie brick 500 megs
nero has a program that ripps dvds ..4.3 gigs is huge file to look at alone open it.. I dont know the limits? for my biggest file was 800 megs mpg.
Top Cavalry Storage Computers & Internet Experts
Marvin
Marvin
Are you a Cavalry Storage Computer and Internet Expert? Answer questions, earn points and help others
