Question about Philips Vacuums
Can I buy a new head for philishave #5401 - Philips Vacuums
Posted by sometime816 on
Andy Turner
  • 910 Answers
Replacement frames can be purchased as at the link below.
http://www.espares.co.uk/part/mens-shavers/philips/p/1114/128/0/0/540130/philishave-electric-razor.html
Or replacement blades can be purchased as at the link below.
http://www.shavercentre.com/canada/philips_parts.html
If you need any further assistance then if you advise what country you're in I'll look into it further.
Posted on Aug 27, 2011
The power cable connected to the philishave has got burnt. to be replaced/repaired
The cable must be replaced as soon as possible to avoid any short circuit and damage to your appliances.
Nov 08, 2010 | Vacuums
Can I buy a new power head and floor brush head for the harmony....bought in 2004-05 and if so where?
Hi, EVacuumStore.com sells a good selection of parts for the EL6985. If they don't have the parts you are looking for, try BizRate.com, which has links to a lot of different parts (including heads and brushes).
If this solution was helpful to you, please consider rating it. Thanks!
Jul 03, 2010 | Electrolux Harmony Canister Vacuum -...
Brush head not spinning
Belts broken, buy a new belt
Mar 21, 2010 | Dyson Vacuums
Belt on turb0 head is slipping
Just buy a new belt from a domestic appliance spares store or online store and replace the old one.
Oct 14, 2009 | Dyson DC05 Cylinder Bagless Canister...
Brushroll in electrolux oxygen+ deluxe
Is the brush roll not working at all? Check the teeth at the sides of the brush roll by opening up the electric head. If it has completely been destroyed you may have to buy another new head for it. Separate brush rolls are difficult to obtain and work out more expensive sometimes than the electric heads themselves.
You may have to contact the Electrolux cust services in your own country. Check by Electrolux.com
Jul 24, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Hi my vacuum (Russell Hobss 2200 bagless HEPA) seems to have just enough ( not loads) of suction til it reaches the cleaning head. the head does not appear to be blocked - but there is then almost no...
Generic problem for all Vacuums
Hi my vacuum (Russell Hobss 2200 Bagless HEPA)
Hi my vacuum (Russell Hobss 2200 Bagless HEPA) seems to have just enough (not loads) of suction till it reaches the cleaning head. The head does not appear to be blocked - but there is then almost no suction at all.
It also makes loads of noise when on- and an even louder noise when turning off.
is it fixable or is it dead?
Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Well there seems to be maybe a few problems, the head may be clear, but the hoses could be clogged and or the HEPA filter could be clogged as well – if the hoses and wands are clear and the filter clean you may look @ a motor replacement depending on the cost or to buy a new vacuum and in some instances you can trade in your old vacuum for a new one – but check it fist from the suction head thru the hoses, wands and filters, B4 you decide to purchase a new one or to replace the old motor with a new one depending on cost. A rule to live by – the item cost more to repair that to replace – replace the item, if the repair cost (as an example) say $50.00 to $60.00 and to buy a new one would cost $100.00 – buy a new one.
Don – The Vac Man
Apr 21, 2008 | Vacuums
Vacuums Logo
306 people viewed this question
Top Philips Vacuums Experts
Tim Venetis
JonSnell Electronic
JonSnell Electronic
Attique-ur-Rehman
Attique-ur-Rehman
Are you a Philips Vacuum Expert? Answer questions, earn points and help others
