Question about Samsung Televison & Video
My Samsung HdTv will not come back on. Only a small red light next to the power button is blinking. First it was blinking six times then five now six again. Model TXR3079 or 8WHKXXAA. Samsung hdtv 1080i 42 inch flat screen.
Posted by ms_mccu110ug on
Anonymous
    Sergeant:
  • 184 Answers
Hello, You need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where, If you need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where. power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement. Hope this will help to solve the problem
Posted on Aug 27, 2011
Why does it have six red blinking lights?
Hi Tim
In my opinion
No... the LED's are doing their job
Error reporting
Modern TV's are computers and try to indicate where a problem exists.
Does it need a Firmware upgrade?
Red green or orange lights are on or blinking on the TV
Sep 22, 2015 | Sony KDL-50R550A 50" LED TV 1920x1080, 240...
My KDF-55WF655 power led blinking red six times.
It looks like your power module is on the blink. Do you get any picture?
Jun 13, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Red light blinks six times. When I hit power button green light stays on for a few seconds, turns off the on for a few more. Then goes back to pattern of red light blinking six times.
the kill switch is open ensure the lamp cover presses firmly on the kill switch when u close the lamp chamber door the red light will stop blinking and u can now turn the tv on
Jul 06, 2013 | Televison & Video
Red flashing after tv turn on for KDS-R60XBR1
How many times does the red light flash before it pauses and then starts again? This is important info as it helps to diagnose your problem.
Mar 20, 2013 | Sony Grand WEGA KDF-55WF655 36" Rear...
MY wega 42inch wont turn on...the little green light flashes like five time as if it where to turn on but never does...and then it turns red and flash six times pauses and then again the red light flashes...
Six blinks indicates a faulty power supply. often caused by open thermistor located at under lamp assembly or beside it. Or a defective regulator on power supply section.. Check the thermistor and replace if found defective.. Or contact the nearest Sony service center at your area.
Oct 01, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
2002 Panasonic PT-47WX52F - Power button now just blinks 3 times
thats the convergence circuits needing repair. You can repair it yourself for around 50.00 with the convergence repair kit for your model from www.tvrepairworld.com the kits contain the parts and the CD with instructions.
Mar 28, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Sony bravia tv not working
Hi Elaine!
Please follow the steps mentioned below to troubleshoot the issue:
If the TV standby light is blinking for five times then you may perform the steps given below:
(i) Turn off the TV then disconnect all the cables from the TV.
(ii) Next, reconnect all the cables after two minutes.
(iii) Please make sure that the power cable from the TV is directly connected to a functional wall outlet.
(iv) Next, you may try resetting the TV to the original factory settings.
Please follow the steps that are mentioned below to reset the TV to the original factory settings:
(a) Turn ON the TV.
(b) Press and hold the Power button on the Remote Control supplied with the TV, then press the Power button on the TV front panel.
(c) Release the Power button. The TV will turn itself off, then back ON again.
(d) Next, release the Reset button on the Remote control.
If the standby light still blinks then the issue may be with the projection lamp in the TV and requires replacement.
Jul 12, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
My Samsung SPN4235 42 in. HDTV
you could to go to samsung website to call the customer support to get an authorized repairman to fix it for you,unless it is still under warranty which you should take it back to the retail store you got it from.
solutiondoct
Jul 30, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Lamp or Bulb
Yes that is the indicator telling you its time to replace the lamp in your unit.
Jun 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
No picture or sound - Error code with Six blinks
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206
Sep 24, 2006 | Sony KP-57WV600 57" Rear Projection...
Televison & Video Logo
Demonic-2011
Demonic-2011
