Problem is in either power supply or the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
often that *needs* to be done in a service center as there are some adjustments to be made after replacement.
If otherwise The T-CON board is usually under a metal shield cover and sitting on the middle top section of the screen, you will see a very thin connector with VERY SMALL WIRE attached to it, be real careful when you try to remove this connector.
Make sure the number as printed onthe PCB match the one you are getting, since TV can have more than one version.
As you can see, there is F1 fuse on the left side of the connector.
Check to see if you do have 12v on it and it is not blown.
Hope this will help to solve the problem....
