Question about Samson Audio C01upak C01u Microphone and Podcast Pack
My samson microphone c01u works but i cant hear my mic thru my speakers it does not record out
Posted by deedocdee1 on
PBandJ
    Problem Solver:
  • 29 Answers
That's normal. You're supposed to record a track and then play it back. In order to hear it live you would need to enable "software playthrough" in your recording software, but there will be a delay, so it probably won't be much use.
Posted on Aug 03, 2014
3 Related Answers
Anonymous
  • 27 Answers
SOURCE: Samson C01U USB mic not working on my PC.
try this;
1.using different usb inputs on your pc desk top
2.update drivers on both your desk top and laptop
3.using a different usb cable
if it works fine on your friends computer most likely its not the mic
Posted on Feb 26, 2009
Anonymous
  • 12 Answers
SOURCE: samson c01u vista drivers
No. From their website...
Note: Samson SoftPre is not compatible with Windows Vista however the C01U, C03U and Q1U are all Plug-and-Play compatible with Windows Vista.
Posted on Aug 15, 2009
Anonymous
SOURCE: How do i get my samson c01U mic to work with
plug your condenser microphone into your computer before starting up the cubase program; then after you plug it into your computer start cubase; when cubase loads, press the [F4] key, then that will bring you to the audio configuration menu, there will be a speaker option and microphone option or what ever that stuff is; go to the microphone option and choose the microphone that you are using, then after you choose your microphone setting click close; then after that make create a [audio] then on the audio tab you will see a red button, by pressing that it will allow you to record, but there is another button beside it called a [monitor], press that button then it will allow you to hear your voice while you record your vocals. hope this help.
Posted on Dec 01, 2010
How do i get my samson c01U mic to work with windows vista and cubase le?
Apr 21, 2010 | Samson Audio C01upak C01u Microphone and...
Is the position of my CO3 Samson Mic. in the right place
exactly how did you place your mic? Because in the picture you are showing there are placed two or three mics. The best sound quality does not always depend on the up or down position of your mic. It has a lot to with the acoustics of the room you are recording in, the distance you vocalist is standing and even of you use a windscreen or a reflection wall. The best advice is clap you hands a few times in your room and make sure the clap turns dead. If you clap go's silently dead, without hitting any walls or windows that reflect the sound, than you will have a good position to record.
Mar 02, 2010 | Samson Audio C03upak Co3u Microphone with...
No live sound using Samson CO3U and Windows 7 x64
I don''t think you can solve this problem. The problem is that the computer has to digitize the incoming audio, then echo it out. This conversion takes time and is also governed by the real time clock servicing of the devices. You could try upping the priority of the conversion process, but I don't think you are going to be satisfied with the result either.
You would be happier to use a mic and external mixer where the audio is true real time rather than having the conversion latency time.
Jan 29, 2010 | Samson Audio C03upak Co3u Microphone with...
Only a dynamic mic works on my lap top not condenser mic
Make sure the 48 volt phantom power is on.
Remember this preamp has TRS BALANCED output. If you run this with a stereo adapter into your laptop, the signal and the inverse will be sent into the L and R channels of your laptop and they will CANCEL!
You need to use a special cable that takes say just the tip of the cable from the ultragain connecting to BOTH the left and right inputs of your laptop.
Sep 21, 2009 | Samson Audio C01upak C01u Microphone and...
Samson c01u vista drivers
Aug 15, 2009 | Samson Audio C01upak C01u Microphone and...
try this;
Feb 25, 2009 | Samson Audio C01upak C01u Microphone and...
Problem with computer recognizing Audio Microphone.
Check if you selected the mic as the default audio input on the respective programs.
Aug 07, 2008 | Samson Audio C01upak C01u Microphone and...
Samson Audio C01upak C01u Microphone and Podcast Pack Logo
Top Samson Music Experts
Lawrence Oravetz
Vernon Taylor
rhodesworks
Are you a Samson Music Expert? Answer questions, earn points and help others
