P0621 Generator Lamp/L Terminal Circuit Malfunction,,The Engine Control Module (ECM) or Powertrain Control Module (PCM) uses the generator turn on signal circuit to control the load of the generator on the engine. A high side driver in the ECM/PCM applies a voltage to the voltage regulator. This signals the voltage regulator to turn the field circuit ON and OFF. The ECM/PCM monitors the state of the generator turn on signal circuit. The ECM/PCM should detect low voltage on generator turn on signal circuit when the ignition is ON and the engine is OFF, or when the charging system malfunctions. With the engine running, the ECM/PCM should detect high voltage on the generator turn on signal circuit. The ECM/PCM performs Ignition ON and RUN tests to determine the status of the generator turn on signal circuit.
