Pool & Spa Logo
Posted on Aug 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an E02 message and was just wondering if there are any adjustments that I can make. I have already turned the gas off and back on and checked the filters.
Anonymous
Level 2:
Sergeant:
  • Expert 368 Answers
  • Posted on Aug 27, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
368
Questions
Helped
134943
Points
582
The E02 message says there is a high temperature condition. There are two sensors that detect this condition and a number of things can cause it. If the combustion gas or water flow is not high enough it could happen. One or both sensors could be bad. The flow regulator could be defective, etc. . I recommend you call the Pentair technicalsupport at 800-693-0971 and they should be able to help you figure this issueout. I hope this helps.
Please vote on this answer. Thank you.
How to setting E02-02 code panasonic photocopier machine
Hi.
Panasonic Workio DP-1820P error code E02-01 These instructions describe error code E02-01 solution for a Panasonic Workio DP-1520p, DP-1820P copier machine. This should solve your problem; this introduction will help you to troubleshoot some common error messages related to Panasonic Workio DP-1520p, DP-1820P Error Code E2-01, E2-02, E2-03, and E2-04 that you may receive.
Meaning of E02-01 the Error Code:
E02-01 means the Tray 1 cassette lifting motor unit fault. These machines use a lift motor encased in a plastic drive gear casing. Usually something inside the casing breaks, this usually happens in trays that have Ledger or Legal paper installed. The weight of the paper can cause these gear packs to break. Also if the customer loads letter paper in a tray set up for larger paper sizes.
How to fix the error:
Maybe a problem with tray 1 lift motor either you have a bad motor, Pull the paper tray out and see if the paper is lodged behind the tray, Also make sure the white coupling on the rear wall is in one piece. Check that the flag on the back of the tray is still present. Mostly it is broken and sometimes can be repaired, and otherwise, you have to change it, and to open the back cover and reach that (Part no is (DZTY000357 Paper Lift Motor Assembly, lift up drive).
Some of the possible causes:
  • Remove the tray and check for paper behind the tray.
  • Check paper falls back causing the gears to break.
  • Check cassette Lift Motor connector.
  • Replace the Tray 1 lift motor.
  • Check the Mainboard.
Good luck.
2helpful
3answers
I discovered Whirlpool hot water heater was displaying E02 error code. Followed directions in manual to possibly correct problem, but E02 code continued to be displayed. What is the remedy for this?
Error E02 indicates that the water temperature exceeded high limit.
Switch off the house circuit breakers dedicated to the water heater and then press the reset button located behind the control panel on the water heater.
Switch house circuit breakers back on.
If error persists, call a service engineer.
good luck
Error message E02 on Reebok ZR8 Threadmill - please help if possible
If you wish to get some details about treadmill error codes ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Fault E02 on Seimans dishwasher
I think you already raised this problem and I have answered.
The model number is usually plated on the left inside panel of the door, however, that is not always true and could be at the back which is hard to get to unless you take the dishwasher out.
The E02 error with Siemens dishwashers would mean the washing is happening without the heater turning on. This means the dishes may not be coming clean, the wash cycle is long and dishes do not dry.
It is linked to heater relay in control unit being faulty and could be also related to the heater itself being faulty. Worst case both are to be replaced.
A very costly affair. Would help if you can find the model number.
Dec 29, 2012 • Dishwashers
3answers
2answers
My Eternal Hybrid natural-gas hot water heater, Model Number GU195 stopped working, and gives a E02 error code. When the heater automatically attempts to burn, the natural gas doesn't, until the...
I'm having a similar problem. My water heater is Eternal GU195S. It will heat up the water it's in the tank so I will get hot water for a few minutes. Then whenever the system tried to heat up on-demand, it will not heat up and gave E02 error. If I stopped drawing water, the E02 error will go away and the temp setting I had will come back on. What could be the problem? I currently took it out of service and set it up outside my work shop for testing. Thanks.
2helpful
Hi Have got a hoover optima about 18 months old. Has got an E02 message in the middle of a cycle because the water board have turned the water off without telling anyone. Can't open the door or get...
'E02' for your Hoover Optima states 'fill time-out' which is not surprising considering that the water board turned the water off!
I hope by now that the water is back on and so is your washer ;-0)
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
E02 message
Error relates to water taking to long to get into machine. Check tap is open fully, water pressure is ok, hoses are not kinked. also check the small filters either end of the inlet hoses (inlet valves as well) as quite often they can clog up especialy on a new install. Regards
E02 Code
Faulty heating element, or main eprom is faulty
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
ZJ Limited
ZJ Limited
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
