Pioneer SX-205 Receiver Logo
Question about Pioneer SX-205 Receiver
My pioneer sx311r has power but no sound - Pioneer SX-205 Receiver
Posted by p4100 on
Pioneer how do
It depends what you mean by "audio"? Or more precisely what audio from where? For example if a DVD player is connected only to the Pioneer then when the power is switched off, the Pioneer can not route audio from that to the TV. The best way of connection is to have everything running into the TV and then feeding the audio out via an optical cable connected between the TV and Pioneer. This will send high quality sound to your receiver when its on, but allow you to watch and hear sound without it.
1helpful
I have 2 pioneer 6x9 400w, pioneer GM 6500f 760w amp and a kenwood KFC W1012 sub, how d i get the best sound from these?
pioneer gm 6500 is a 4 ch amp rated at 60w-4 way to small of an amp to run your sub. UNDER-POWERING your sub is more likely to damage spkr than over-powering. my advice,get mono-block to run sub
If you need further help, I’m available over the phone at https://www.6ya.com/expert/stephen_fa62cb6d50fe05e8
PROBLEM WITH SUB WORKING ON A PIONEER VSXAX5I RECIEVER
The problem is in the powered sub, the buzzing sound is caused by one or more defective audio output ic's that drive the subwoofer directly, service is the only option to remedy the situation.
How do i connect Pioneer DEH-P4700MP at home
If you are looking to connect this radio at home, you will first need some kind of 12V DC power supply with an operating range anywhere between 9-16V. You can purchase these online or at most electronics retailers (Radio Shack, Fry's Electronics, etc.). Simply connect the constant memory power wire (yellow) and switched accessory power wire (red) from the Pioneer's wiring harness to the "+" terminal on the power supply and the ground (black) wire of the Pioneer to the "-" terminal on the power supply. Make sure to have at least one speaker connected to the speaker output leads of the Pioneer for sound. The speaker connections are as follows: Front Left + (white) FL - (white/black stripe), F Right + (gray) FR - (gray/black), Rear L + (green) RL - (green/black) RR + (violet) RR - (violet/black). And that's it! Sound at home with your Pioneer radio!
I hope this information was helpful.
2helpful
Power sub woofer is not working on my pioneer vsx-81txv everything is working all the speakers except the power sub connection at the back all i can hear is the hissing sound when i try to connect the sub...
Hissing? How loud? A sub isn't even capable of making high frequency sounds at normal volumes.
The Pioneer manual would tell you how to enable and test the subwoofer output.
Page 17 and the MACCV procedures on Page 33 (auto) or 43 (manual)
Pioneer Elite. Loud popping sound and picture disappeared
Power supply board is dead.The board where the power a/c cord plug into it.Replace the power supply board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Pioneer stereo receiver has sound and power problems.
i would suggest checking the wires on the speaker switch board, thats usually the main cause of this problem..but i dont recommend buying pioneers newer stuff
Need a manual to download for pioneer VSX-43TX
pioneer is really good about providing pdf manuals just google pioneer electronics ltd
Pioneer Plasma TV powered off and won't power back up
Power supply failure-checked Pioneer's website, there is a recall on the power supply.
Top Pioneer Audio Players & Recorders Experts
David Shaub
Steve
Morne Olivier
Morne Olivier
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
