VuPoint DC-M306AT-VP Digital Camera Logo
Posted on Aug 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Unable to locate a 1 MB SD card for my camera, in my area.
Anonymous
Level 3:
Brigadier General:
  • Master 11,967 Answers
  • Posted on Aug 27, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
11967
Questions
0
Helped
2200535
Points
38521
There's no such thing as a 1 MB Sd card. Do you really mean a 1GB SD card? Try amazon.com
1helpful
I have a Konica minolta with 512 MB memory.How much more memory of SDhc/SD card can it use as it is unable to use 4GB SDHC card. Thanks.
The Z1 uses SD cards, which top out at 2GB. SDHC cards do not work with this camera, as you've already found out.
What size memory card does the kodak easyshare cx6200 take?
The internal memory for this camera is 8 MB.
The manual indicates using memory cards of size 8 to 128 MB, so this is an early SD memory camera, following the original SD standard. Do not try SDHC or SDXC cards. The camera will support a 1 GB card. It *might* support a 2 or 4 GB card, but since this is a 2 Mpixel camera, a 512 MB or 1 GB card will allow you to save thousands of jpeg format pictures.
I can't find the memory card for it
According to the specifications the camera has both an in-built mmory, and also accepts an SD card with a maximum of 512 MB . Maybe it will accept a larger SD memory card but only record up to 512 MB? I do not know.
SD cards are common in camera stores, but these days they make them with 1, 2, 3 or even 8 GB ( 1GB about 1000 MB) !
1helpful
Should you use an 8gb sd memory card in a panasonic lumix dmc-fx3 camera ?
The manual lists the following SD cards compatible:
4 GB SDHC Memory Card
2 GB SD Memory Card
1 GB SD Memory Card
512 MB SD Memory Card
256 MB SD Memory Card
128 MB SD Memory Card
64 MB SD Memory Card
An 8GB card may or may not work. If you try it, make sure it is an SDHC card. (Note: HC=High Capacity)
Thanks for using Fixya.
3helpful
2answers
Can I use 1 mb sd picture card
No. S7000 can use XD cards (available upto 2GB) or CF cards up to 1GB
I have the kodak c310 and have tried all the following 128MB 256 MB and 2g none will format and gives file error why?
Your camera is only supporting SD/MMC Cards (up to 1 GB only)
The cards that you currently have might be faulty.
Please try another card.
You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
2helpful
2answers
Z3 will not accept a 2g card
The Dimage Z3 accept SD cards up to 1GB (Minolta says 512 Mb, and sold it with 16Mb). This camera is 4MP , and uses less memory on card, therefore a 512MB card will be enough for it.
SanDisk Flash memory card - 512 MB SD Memory ...
from $13 - 20 stores
PNY Flash memory card - 512 MB SD Memory Card ...
from $3 - 2 stores
SanDisk SD Industrial Flash memory card - 512 ... from $14
Here 1 Gb, try at your risk, but they normally work:
1GB micro SD memory card for Konica Minolta ...
£6.90 - www.mobile-laden.co.uk
1GB Flash Memory Upgrade Card for Konica ... £3.44 - Memory Express
Here review: Steves Digicams - Minolta DiMAGE Z3 -
Nikon Coolpix 4600: Problem: It won't take any photos, it reads: THIS CARD CANNOT BE USED. The card is 128 MB. I purchased a new card: 2GB but it won't work also. My manual says to clean the contacts...
1) Have you formatted the cards?
2) Try the cards in the card reader in your computer to see if they can be read.
3) Try the "switch off camera - remove and replace battery - switch on camera" trick with the original 128 Mb card in place. This will reset the camera's memory.
4) Note the type of card is important - not all cards can be used in a camera (especially some of the latest bigger ones) - check the type of cards supported by your camera.
I found this at the Nikon USA site (note that the 2 GB card is not listed - as said "Cards are not all the same" and use different drivers to operate them):
Question Which Secure Digital Cards are approved for use in the Coolpix 4600/5600? trnsp.gif Answer The Nikon Quality Department has tested the following cards and approved their use in the Coolpix 4600/5600:
SD memory cards:
SanDisk 16 MB, 32 MB, 64 MB, 128 MB, 256 MB, 256 MB*, 512 MB, 512MB*, 1 GB
Panasonic 16 MB, 32 MB, 64 MB, 128 MB, 256 MB*, 512 MB*,1 GB
Toshiba 16 MB, 32 MB, 64 MB, 128 MB, 128 MB*, 256 MB, 256 MB*, 512 MB
*High speed type of 10 MB/s or over
Other brands and capacities of cards may work, but Nikon cannot guarantee their operation. Check with the manufacturer of the third-
party card for compatibility information. Nikon recommends keeping one of the approved cards available for troubleshooting.
1helpful
Incompatiblity of R300 & Toshiba 2 GB SD Memory Card
Epson Printers & All-In-Ones:
MEMORY CARD TYPE MAXIMUM CAPACITY TESTED Compact Flash 4 GB Secure Digital 1 GB Sony Memory Stick 1 GB MagicGate Memory Stick 128 MB xD Picture Card 512 MB Smart Media 128 MB
These are the Epson tested memory cards that will work, also includes the suported memo capacity..
Hope this is helpful, pls dont forget to rate solution.
Top VuPoint Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a VuPoint Camera Expert? Answer questions, earn points and help others
