Wont turn on
first ck your fuse panel either from 15 to 25 amp bottom of your left leg if the driving position of left side or European on right side,than you might also have to ck that hot wire constint at the back of a radio"IF "the fuse is not the problem,and power wire when Ignition is turn ON...you will need a test light and a volt meters.but do not used a meter to ck. for AMP unless you have a best volt meter could handle with 25 amps and over..ck all your radio connt. wire if its loose wires or radio tips contact with wire connt.,,ck for grown and negative connt. also...some model of a radio aftermarket have a fuse at the back of the radio also,you will need to ck that with test light is it OK or not,if all seem to work fine than Sorry is RADIO need to replace....REMEMBER any radio is over 1db will cause your hearing problem in the future remember thats when you turn on too much of a WATTS
