Samsung intensity I problem. after 2 days of non use, i turned it back on, and half the keys are not functioning at at all. ive taken out the battery and stuff, but is not working.
there are 1million answers on this googling, more really
ive posted the 6 causes. of a dead starter vast times.
in your case is but 1 of 6
the alternator is dead, fuse blown to it? or wires to it damaged or fell off?
the USA car , the alternator is listed as internal regulated, a good thing that)
bad alt, or fan belt to it slips. wires bad to it, fuse blown to it.
this car sports 3 engines offered day 1 new here.
non told. 113, 271 and 272
1.Check the device's battery level for at least two bars of strength. 2.If the battery level is low, charge the battery. 3.If the issue is not resolved, remove the back cover. 4.Remove the battery. 5.Wait 10 seconds. 6.Press and hold the W key. 7.While pressing down the W key, re-insert the battery. •The device restarts and after approximately 15 seconds, the 'Recovery' screen appears •Release the power button but *continue holding the home button*, for another 30 seconds. Step Thanks
Clean the battery connector(3 golden metals)
Clean them very easily and carefully with something blade like a small blade.
It seems they got some rust.and the mobile cannot recognise the battery
Adjust the volume of the key tones In Idle mode, press [up /down] and adjust the key tone volume.
Adjust the vibration intensity on the touch screen You can adjust the intensity of the vibration when you tap the phone screen. 1. In Idle mode, press [up /down]. 2. Select Vibration and adjust the intensity of the vibration.
More often then not its the battery even tho the battery is fully charged as it may seem. The rel test is get a new battery not your friends battery tho but a new one put it in there and let it charge. If that doe not work then the phone's logic board has been effected and it may or might not be worth reviving. But check the battery first.
Please do be considerate and leave ratings and feedback for all experts involved in helping you out today, thanks
The port on a Samsung Intensity is located inside the back cover of the phone. Take off the back of the phone, and you'll see the port, right next to the camera key button. (You won't need to remove the battery.)
