Cameras Logo
Posted on Sep 11, 2017
I have an Haier Portable DVD 2/7" TFT LCD Monitor with an Haier Battery PBAT-118. I can't open the Haier Battery Pack PBAT-118 to insert new batteries so that I can play my Haier Portable DVD without plugging it in the wall. Electricity might go out and wanted to make sure I could use my Haier Portable DVD just in case. Please let me know. Thanks! Debra
5 Related Answers
A
Anonymous
  • Posted on Jan 10, 2008
SOURCE: Battery charging
My DV179 didnt come with the charger! What do I do now that my battery is dead???
Anonymous
  • 487 Answers
  • Posted on Apr 24, 2008
SOURCE: Panasonic Lumix DMC-TZI - broken battery tab and battery/card door
well there is no easy way. You will have to open the machine up when you have ordered the parts you needed. Not to hard but make sure you keep you eye on the sequence how you pull it apart.
Anonymous
  • Posted on Jul 21, 2008
SOURCE: flashing red light on my battery pack charger
Hey, I just had this problem with a Sanyo battery pack (and i thought it was the non-sanyo Li battery) and noticed it wasn't getting warm even 2 hours after "charging" and the red light was flashing - so i turned it off, disconnected the cable from the charger and realised it could go the other way, so tried that AND IT WORKED! i don't know what that cable is called, the 2-prong black cable, but give that a go (turn off in between!).
Anonymous
  • Posted on Oct 07, 2008
SOURCE: powershot sd 400
have same problem with canon sd10. bought new battery and new charger, THIS IS A CANON HARDWARE PROBLEM I assure you
Anonymous
  • 70 Answers
  • Posted on Apr 15, 2009
SOURCE: Camera shows low Battery and goes off even if u insert a new one
are you using NiMh rechargeable batteries?
If yes, check that they are fully charged. If that doesn't do the trick, sounds like it might be a power circuit issue. Samsung is in Secaucus, NJ
or SamsungUSA on the web
Where can I find a battery pack for a Haier portable DVD 7" player?
try contacting R&D battery on the internet. They are good to "repak" your batteries with fresh cells if you can not find the proper new batteries.
1helpful
Need a battery pack for Haier PDVD9KIT - DVD player
Contact Haier Tech Support here:
http://www.haieramerica.com/en/support
3helpful
Haier dvd player model PBAT-118 battery pack does not work. where can I get another one?
Try contact Haier Tech Support here, they should have a replacement battery pack:
I have one of these units, and as yours, the battery pack quit working. I found out the electronic charging board it has inside is defective, it could be yours too.
2helpful
The battery does not charge
My mother has one of these units, it was working fine until recently I took it to play with it, and found the same problem you describe. The unit works with the power supply (what some people call the "cord") attached directly to the unit, it works through the connector on the power pack itself, but the LED on the battery is not on as used to. I opened the battery pack and found it has an electronic board close to the power connectors, that board might be defective now, yours might be have the same problem. I'm an electronics tech, but I can't fix that board with surface-mount compontens.
Solution: Contact Haier to see if you can purchase the battery pack. In my case I could replace the internal charging board, if they sell it separate, which I doubt but never hurts try contact the factory.
3answers
I need a new battery pack for haier 7
#1 www.amazon.com
#2 www.newegg.com
www.AllBatteryCenter.com
www.BatterySpace.com
www.battery-laptop.org
2answers
New Haier 7.2V rechargeable NI-MH battery pack for a new Haier Portable DVD player was stored in a drawer for 2 years until recently. Attemped to recharge battery pack via electrical outlet. Obtained...
the battery pack is charging but not holding charge beacause it was not used for a long time as you said.try to recharge and completely drain the batteries a couple of times and the batteries should start holding better the charge.Another thing you may want to check is if there is power coming out at teh battery pack connectors(you will need a small volt meter)
7" tft monitor portable dvd player
I have 8.5" TFT widescreen Monitor Portable for three years. Now when I turn it on, it only has sound, the picture only has one second blink, then dark.
I am now in Shanghai,China, is there a service in Shanghai which I can go physically to get it repaired?
xujingcan
2helpful
2answers
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
