Question about Mitsubishi WS-55613 55" Rear Projection HDTV
Sreen has perfect color and then fades to a cloudy/faded picture. occassionally picture will go full color then very yellow,very red, cloudy/faded.
Posted by montgs008 on
  • Anonymous Mar 19, 2014
    faded and cloudy picture do I need to change lamp?
Lou
    Filmmaker:
    Uploaded 5 video answers.
  • 162 Answers
Does it come and go? Or is it like this all the time? If you bump the side of the TV does it change the symptoms? Thanks Lou
Posted on Aug 27, 2011
  • montgs008 Aug 27, 2011
    It comes and goes when it is cold it is gennerlly cloudy after it has been on awhile turning the set on and off it will generally switch to a clean picture. but it will still fade in and out.
No red color on screen
there are three basic color controlled by electronic circuit, in picture tube gun,one of them not working properly.needs detail analysis
Dec 04, 2011 | Mitsubishi WT-42311 42" Rear Projection...
Picture is not very clear and the color is faded and can not adjust it
This mite sound crazy but it is time to change the oil in your TV. Yes your TV has three seperate picture tubes on the inside of it. A red tube, blue tube, and green tube. Each one of thses tubes has a clear oil that the light shines through. Over time this oil gets cloudy and distorts the light thus dimming and fadeing your picture please have a tech change the oil in your tubes.
Nov 08, 2010 | Akai PT4250A 42" HDTV
48'' Rear projection picture fading
sounds like your color wheel is fading.
Mar 31, 2009 | JVC Televison & Video
Faded color display
replace the colorwheel.
Jan 27, 2009 | Eiki EIP-3500 DLP Projector
Seeing red !
I had a television that went to a bright shade of blue.A friends neighbor worked for sony television plant where the new tubes came down the assembly line.His job was to make sure tubes were working fine,if one color was dominant then his job was to smack the front center of the tube with a rubber mallot to fix the problem.He suggested i try that with my tube while the set was on.It worked and solved my blue problem.Apparently he explained,the gun connections in the tube came loose and to fix it was to smack it this caused the connection to reweld itself.For you I would use the palm of an open hand and smack the tube dead center with a good hard smack.Dont be afraid of breaking the glass because its very thick and strong.Give this a try.Hope it helps.Good luck!
Oct 31, 2008 | RCA F25442 25" TV
Color fading on Sony could be cable ?
have the cable company come out and check there cable box and picture.
Jan 28, 2008 | Sony KV-27V22 TV
Color fade
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Oct 11, 2007 | Hitachi 51F500 51" Rear Projection...
Faded colors
If the picture is dark or messed up too bad, the magic focus will not function, are all the primary colors faded? RED GREEN BLUE? You might have a bad CRT, would call a service man to check out.
May 21, 2007 | Samsung HCN5527W 55" Rear Projection...
Mitsubishi WS-55613 55" Rear Projection HDTV Logo
304 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
