SOURCE: Braun Synchro 7680 - "Oil" message
Had the same problem on my shaver too. Bought this product:
http://www.onlineshavers.com/pd_braun_8000_activator_foil_cutter_pack31.cfm
(I know the link says foil cutter, but it takes you to Braun lubricating oil!)
I apply the lubricating oil to the foil etc, then the word "oil" disappears. Then after a while the word "oil" comes back and I apply the oil again and so on, my shaver still performs normally.
Hope this helps.
SOURCE: Braun Syncro 7680 Electric Razor
Great instructions.
I left out the plastic latch and the razor works fine. OK with me.
On step "f" there was a little guide on one side...I had to push that in before sliding the switch upwards...it slid right out after doing that.
Thanks...it helped a lot.
SOURCE: My Braun 7680 says "Oil"
Yes, drizzle some vegetable oil on the blades while running.
Testimonial: "Fast and easy. GREAT!"
SOURCE: Braun 790cc Shaver battery not holding charge
the item has a 2 year warranty. if you have proof of purchase date, you should call Braun for warranty service. Phone number is in your owner manual
SOURCE: I have a Braun 7680, and the switch won't work -
Most likely, the mechanism is broken and will need replaced. The switch is part of the trimmer assembly which comes attached to the outer casing. You will find a replacement at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-syncro-body-housing-select-models-p-811.html
You will also find disassembly tutorial at the link below
http://www.shaveroutlet.com/braun_syncro_shaver_disassembly
