I can send you a complete wiring diagram for your Sportster. The wires you are talking about go to the stock igniton unit, the "brain box" or "black box" that is behind the triangular plate on the right side of the bike as best as I can remember (1984 was a long time ago). There should be two white wires on the coil and one is the "hot" wire and the other goes to the ignition unit. The pink wire goes to the tachometer. The blue wire goes to the opposite side of the coil from the white wire, same side as the pink wire. The black wire is a ground wire for the igntion unit most likely. But, I'm confused by you saying the wires go to a "sensor". The only sensor on the bike is in the timer cavity on the right side of the engine and the wires coming from it are different color from what you mention. Are you sure it's not simply a plug? Contact me directly at
[email protected] and I'll send you the diagram. Remind me of what you need.
Steve
