SOURCE: whirlpool oven doesn't work model gs563lxss
We had those same symptoms with our range out of the box. It was a problem with the PC board and it was fixed under warranty.
SOURCE: whirlpool gold stove (wd sensor open)
on my stove i pushed the lock button for my oven now it want unlock. it is like it is froze up, it want let me cook or anything
SOURCE: stove top works, display unit and oven does not
I would have to say that u need to remove the back painl and look for a ground wirer that is broken or burnt in half. make sur that u unplug the oven first.when u find the problem just replace the wirers
SOURCE: error code E2F1
e2-f1 refers to a bad erc(electronic range control) or otherwise known as the clock, you have to replace the clock assembly.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
SOURCE: F2 Error on Whirlpool Dual Fuel Range
I was baking and the stove suddenly changed to Maxi Broil and then to ERR F2EO Stuck Key. I cannot seem to change it by start or off or even turning the unit off and then back on. Any suggestions? Thanks.
