Question about HP Deskjet 2360 InkJet Printer
My hp deskjet d1400 will not print the green light is flashing and everythimg else works except when printing
Posted by claire_forbe on
5 Related Answers
Anonymous
  • 107 Answers
SOURCE: hp deskjet 3550 problem
Green light blinking is indicated that u r one of the cartridge (or both cartridges ) are faulty .please check u r printer with tested Ok cartridges ...it should be resolved
if this information is useful for u please Rate me .........
u r Rating is Important for me.
Posted on Jun 26, 2008
Anonymous
SOURCE: Hp Deskjet 845C - Yellow Colour not Printing
I found this post to work for me when yellow was not printing on my HP PSC750 after using 2 cartridges: "Well if you want to damage your printer use alcohol. But if you want to make it work then pull the cartridge from the printer and run hot water on a couple of paper towels leaving alot of hot water in the towels. Put some thing under them to keep them from staining your counter top and then set the cartridge down onto the hotwater towel and let the hot water melt away the dry ink and in minutes you may be printing again if this is what it is. Be sure and use a dry paper towel to wipe off the ecess wet before you reinstall the cartridge."
Posted on Sep 05, 2008
guide2u
SS s
  • 461 Answers
SOURCE: HP deskjet F4140 Error light on & I can"t print
please reset your printer. turn off your printer, leave it for 30 sec and turn it on again....
If you still have problem try to re install the catridges again, follow below instruction
http://etech.maiila.com/hp-deskjet-f4140-all-in-one-printer-catridges-installation
Good Luck
Posted on Nov 01, 2008
Anonymous
  • 11 Answers
SOURCE: flashing on/off light on hp deskjet 3520 printer
Introduction The printer lights indicate the printer status. These lights can be on, off, or blinking (flashing), depending on the status of the printer. The sections below describe the most common combinations of blinking lights, how to fix the issue, and how the issue is caused. NOTE: The light patterns included in this document are described as blinking or flashing lights. For the purpose of this document, "flashing" means the same as "blinking." Blinking lights Printer lights can can blink for more than one reason, so the solution can vary. These solutions need not be performed in a specific order, but solutions for the most common issues are presented first. Blinking lights are often accompanied by an error message on the computer screen, which might help determine the solution. Issue: Power light is blinking
c00374282.gif Solution
Close the cover.
Cause
Printer cover is open. Solution
Insert appropriate media in the In tray.
Cause
The printer is out of paper. Solution
  • Change the printer's print mode setting.
  • Change the printer's paper type selection.
  • Use a different brand of label media.
Cause
The printer has difficulty picking up label media. Solution
Follow each of these steps until the problem is resolved:
  1. Remove the paper from both paper trays.
  2. Press the power button once. Wait a moment for the paper jam to clear.
  3. If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
  4. Remove the rear access door.
  5. Remove the paper jam through the opening at the back of the printer.
  6. Replace the rear access door.
  7. Reload the paper into the paper In tray.
  8. Print the document.
Cause
There is a paper jam. Solution
  1. Remove and then reinsert the print cartridge(s) into the printer.
  2. Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
  3. Manually clean the print cartridges and print cartridge cradles:
    • Open the printer cover and wait until the carriage moves to the center.
    • Press the Power button to turn off the printer.
    • Disconnect power cord from the back of the printer.
    • Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
    • Lightly moisten a cotton swab with distilled water.
    • Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
    • Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
    • Reinsert the print cartridges.
    • Close the printer cover.
    • Connect the power cord to the back of the printer.
    • Press the Power button to turn on the printer.
  4. Calibrate the print cartridges.
  5. If the light is still flashing, replace the print cartridges.
Cause
There is a problem with a print cartridge. Solution
  1. Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
  2. Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
  3. Remove and then reinsert the print cartridge(s) into the printer.
  4. Print the document.
  5. If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
  6. Try printing again. If the problem continues, replace the print cartridges.
Cause
The print cartridge has partial loss of electrical interface with the carriage connections.
Posted on Mar 04, 2009
MCSE_Fixit
MCSE_Fixit
  • 23 Answers
SOURCE: hp deskjet 5652 not printing, orange light flashing continuously
1. Check to insure the cover is shut down completely.
2. If the "Ink Drop" Icon is blinking you are either out of ink, or there is a problem with the cartridge carrier. So open the cover - the carriage should move to the middle, if not it is bound up somewhere. Check the guides and around the carriage area for gummy labels etc..
3. If the carriage moves to the middle, release the ink cartridges and replace.
4. If the "Arrow" Icon is blinking, this could be a result of a paper feed error. Remove the paper from the tray, open the cover and insure no jams are in the rollers. Shuffle the paper lightly and place back in tray. Check to make sure the tray is pushed completely forward and then press the "Arrow" Icon button until a sheet is fed into the printer.
* * Note: When you are replacing the Ink cartridges and before you remove the tape from the bottom heads, give them a shake to lossen up the ink before installing.
This link will take route you to HP's support and more troubleshooting techniques for your printer.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00013363&lc=en&dlc=en&cc=us&product=304442&rule=35720&lang=en
Hope this helps..
God Bless.......
Posted on Jun 18, 2009
Hp deskjet 948c. What Do The Button's Do
buttons and lights The HP Deskjet printer buttons let you turn the printer on and off, cancel a print job, or resume printing. The lights give you visual cues about the state of the printer
sayurisan20_33.jpgcancel button
print cartridge status symbol and light **The light above the Print Cartridge Status symbol flashes when a print cartridge is low on ink or incorrectly installed.
sayurisan20_35.jpg resume button and light
**The light above the Resume button flashes when an action is required such as loading paper or clearing a paper jam. When the problem is fixed, press the Resume button to continue printing.
sayurisan20_36.jpg power button and light **
The Power button turns the printer on and off. It takes approximately five seconds for the printer to turn on after you press the Power button. The green light above the Power button flashes when printing is in progress. Caution! Always use the Power button on the front of the printer to turn the printer on and off. Using a power strip, surge protector, or a wallmounted switch to turn the printer on and off may cause premature printer failure
Jun 17, 2011 | HP Office Equipment & Supplies
Sir i am purchase a new hp cartige but problem is printer cartige problem my printer name is hp deskjet d1400 how to solve this problem????
There can be number of problems related o printer cartridge. In order to assist you to solve the problem please specify what exactly is the problem like, no ink, alignment, dirty printing etc.
Nov 18, 2010 | HP DeskJet F380 All-In-One Printer
HP 920c Deskjet feeds blank paper constantly. Will not print. Just shoots paper out.
deskjet 920c will not print, green light flashes and blank paper comes out. Printer will print test page perfectly.
Nov 07, 2009 | HP DeskJet 920c InkJet Printer
The printer will not work. The green bottom
The Print Cartridge Status light flashes when one or both of the print cartridges is improperly installed or malfunctioning.
1. Open the printer's top cover.
2. Remove and re insert both the black and colour print cartridges and try printing again.
If the problem persists then you need to replace either the black or the colour print cartridge.
Sep 21, 2009 | HP DeskJet 5550 InkJet Printer
On/off light keeps flashing green and will not print.
Your problem can be caused by a couple of things.....paper jam, printer cover open,etc...
But have no fear below is a link to figure out what is causing this problem and the solution to fix it....
Blinking Lights
Apr 27, 2009 | HP DeskJet 3520 InkJet Printer
Hi my name is Alex Irecently purchase a HP Pavillion along with a 22" widescreen the package came with HP Desktop D1400 series, I cannot get it Print what should I do.
Make sure that the driver of the HP Deskjet D1400 series printer is already installed on your computer. Once it's properly installed, try to print a test page and see if you will be able to print.
For technical support, try to go to www.supportrix.com. You may use "suppportcall" as a promocode.
Aug 01, 2008 | HP Office Equipment & Supplies
D1360 black ink didn't print and green light keep flashing
just unplug the power cable and usb cable from the back side of the printer and let it be for an hour it will help
Apr 15, 2008 | HP Deskjet D2360 InkJet Printer
HP Deskjet 2360 InkJet Printer Logo
1,195 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
