SOURCE: how do i collapse the buzz modelof the quinney pram
check the manual at www.quinny.com and there are some good you tube videos as well but basically, stand by the front wheel, position the seat slightly reclined and forward facing. Press the buttons on each side of the seat and pull the hinge forward and down. Make sure it clips shut or it will spring open again.
SOURCE: wobbely and squeeky frame
I would suggest that you first take the pram back to the retailer where this was purchased as they may be able to assist you the best. Alternatively, you can contact www.quinny.com but they will more than likely send you back to where this was purchased if this is still within the warranty period.
I hope this helps.
SOURCE: spring must be missing in handle as pram will not
My husband managed to fix problem. As far as I can understand he threaded a wire up the handle and attached it to the mechanism. Thank you for your response to my e-mail.
