Question about Kenmore Side by Side Refrigerator
Past couple days the refrigerator side is freezing everything. turned the setting all the way back and still freezing......dont know if there is a thermostat and if its a DIY fix
Posted by mdog70_1 on
  • mdog70_1 Aug 26, 2011
    Hey thank you very much! I found the damper door fins frozen open......I think it happened because a few days back, my daughter left the refrigerator door partially open.....would a fix be to un plug, and defrost the damper door, wipe it dry and plug in again?
Brian Gillespie
  • 57 Answers
Damper door is either broken, stuck open or stuck open and frozen with ice. Damper door is located in the top left corner of the "refrigerator side" of the fridge. Damper door may be concealed by an outer plastic covering usually held in place by a 1/4 inch screw.
Thanks and let me know if that helps,
Tips Provided by: www.HoustonRefrigeratorRepair.com Brian Gillespie GOFAR Services, LLC
Posted on Aug 26, 2011
  • Brian Gillespie
    Brian Gillespie Aug 26, 2011
    A womans hair dryer should do the trick.
    Thanks and Please Rate Me!
    TIPS Provided by: www.HoustonRefrigeratorRepair.com
    Brian Gillespie, President & CEO
    GOFAR Services, LLC
ID020851
    New Friend:
I have a Kenmore Refrigeratro side by side model 106.56573400 and I need to change the refrige side gasket. But I don't see any screws that hold it and it seems to be held in place by the inside panel (pressure). Any suggestions?
Posted on Sep 05, 2011
All cans in the bottom drawer freeze in a couple of days
What temp do you have the fridge set on? The bottom is always the coldest part maybe dont run the fridge as cold or put the cans in the door or at a higher part of the fridge.
May 22, 2014 | KitchenAid KSRD22FKBT / KSRD22FKWH /...
GE Profile Side-by-Side Refrigerator gets to too cold
turn the temp setting up to40 then check in a couple of hrs
Nov 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
I have a side by side Fridge. Model TPX24PRBBWW
turn the controls to factory settings and give it a couple of days, if it is too cold the ice can not release!!
Nov 15, 2009 | Refrigerators
Frigidaire refrigerator freezes everything with setting on lowest
hello there,
try to check your thermostat setting adjust below gradually,
you set it up to coldest point that's why it's doesn't cycle on no auto shutt off and shut on,
if still not change for 12 hours still freezing up,replace thermostat by your technician,might defective.have a nice day
don't forget to rate me,thank's a lot.
May 05, 2009 | Frigidaire FRS26H5AS Side by Side...
GE TFX22R SIDE BY SIDE
you defrost problem or check condenser fan at the back of refrigerator see if it runs
Apr 07, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
Kitchenaid side by side too cold. Freezes everything.
the damper motor on the refrigerator portion is not working properly
Apr 04, 2009 | KitchenAid Superba Architect KSCS25IN Side...
Fridgidaire refridgerator - adjust water level in ice maker
Hello....remove the from cover on the ice maker, and adjust the water flow screw inside. Turn the screw in the direction of the (-) negative side by half a turn to start. Adjust as needed. I hope this helps. ;)
Jan 17, 2009 | Frigidaire FRS26R4A Side by Side...
Everything freezing in vegetable and Custom Cool compartment
you have a temp setting above those shelves left side has a porkshop and left side has a carrot i belive set to to the left side to vegies and see if it helps if still all freezes the you have a broken damper on top that letts air in when it does not needed
Sep 26, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerator
need model number cant help if we dont know what meodel it ios but if everything freezes repl the thermostat in refrigerator side
Aug 16, 2008 | Frigidaire FRS266ZDSB Side by Side...
Kenemore side by side refrigerator made by Frigidaire freezing everything in fridge
on some models you can by pass the filter assembly you can do this by looking at the rear of the ref.at the water inlet valve you will see the lines going to the filter remove these line and look at the way the water goes into the ref you can move these lines around to bypass the filter this will tell ya if the filter assembly is bad I have seen where you cant use the filter on these machines and have to go to a in line filter.good luck and get back to me on this i will help you as much as i can
Jan 07, 2008 | Sanyo SR-3620 Compact Refrigerator
Kenmore Side by Side Refrigerator Logo
356 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
John Tripp
John Tripp
gbob59
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
