Question about Panasonic PT-51HX42 51" Rear Projection Television
It sounds like your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Posted on Aug 27, 2011
Jan 22, 2011 | Philips 60PP9363 60" Rear Projection...
Jan 20, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Feb 07, 2010 | Mitsubishi WS-55807 TV
Jul 17, 2008 | Sony KP-57WS500 57" Rear Projection...
Jul 09, 2008 | Samsung HC-P4752W 47" Rear Projection...
Feb 17, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Dec 07, 2007 | Samsung HC-P4752W 47" Rear Projection...
Dec 02, 2007 | Hitachi 50UX57B 50" Rear Projection...
This sounds like your convergence correction amplifiers have malfunctioned. These Integrated Circuits often burn out after a few years (STK392-110) they can be replaced with a higher version (STK392-150) However it is important to have the biasing circuitry checked to make sure nothing has burnt out as a result of the ICs malfunctioning. If you have a background in electronics you can repair this problem with very little effort, however if you do not have a background in electronics, I would suggest that you have your TV serviced by a qualified TV technician.
I hope this helps,
Thank you,
Shuttle83
Oct 15, 2007 | Mitsubishi WS-55711 55" Rear Projection...
Apr 03, 2007 | Sony KP-57HW40 57" Rear Projection...
