Cars & Trucks Logo
Posted on Aug 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lights flickering ON 1994 CHEVY K1500. Just hooked an amplifier up and headlights are flickering @ night. The amp is not powerful @ all so I didnt think i needed a capacitor
Anonymous
Level 2:
Scholar:
  • Expert 157 Answers
  • Posted on Aug 26, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
157
Questions
0
Helped
59691
Points
437
If you're running it to the battery post directly its creating a strain-you'll need a power distribution block. Also consider a bigger body ground wire/cable. If this doesn't help, you will need a capacitor.
Where is headlight fuse located in a 94 chevy k1500
You'll need to look for fuse number 13. If you want help locating it, follow the link: https://knigaproavto.ru/shemy/en/gmc/yukon/835-1992-1994-k1500-chevrolet-blazer-and-gmc-yukon-fuse-box-diagram.html
1helpful
Lights flicker
When my headlights started to flicker at night, I soon found out it was the battery. It died one night sitting in a friend's driveway with the radio and headlights on. My battery was over 5 years old at the time, and the tow truck driver said I was lucky to have it work that long. I purchased a new battery and the lights no longer flicker at night. Just a suggestion. Hope this helps you.
1994 Chevy K1500 5.7 liter- replaced serpentine belt.next day got a chirp.replaced idler pulley,alternator,and tensioner pulley, but not the actual tensioner.sounds like chirp is coming from power steering...
The chirp is from scale or a glaze on one of the pulleys. If not black or shiney in color clean it with brake cleaner and spray some belt dressing on the pulleys
4helpful
3answers
Chevy S/10 headlights
headlights are on a circuit breaker--not a fuse. so if you have a high amp draw situation--the breaker will get hot and turn the lights out then cool off and reconnect(a safety feature so you may have headlights a least part of the time). You need to look for reasons for a high draw. bad headlights themselves are the most popular cause as well as corroded connecters. Hope I helped
1helpful
Main fuses for the horn and air bag
Fuse #8, #18 and #22.
Below is a listing of which fuse corresponds with which circuit:
1 - 10 Amp - Transmission Controller, Gauges, Autostick
2 - 10 Amp - Right High Beam Headlight
3 - 10 Amp - Left High Beam Headlight
4 - 10 Amp - Radio, CD Player
5 - 10 Amp - Washer Motor
6 - 15 Amp - Power Outlet
7 - 20 Amp - Tail, License, Parking, Illumination Lights, Instrument Cluster
8 - 10 Amp - Airbag
9 - 10 Amp - Turn Signal Lights, Turn Signal/Hazard Indicator
10 - 15 Amp - Right Low Beam
11 - 20 Amp - High Beam Relay, High Beam Indicator, High Beam Switch
12 - 15 Amp - Left Low Beam Headlight
13 - 10 Amp - Fuel Pump Relay, Power Train Control Module
14 - 10 Amp - Cluster, Day/Night Mirror,Sunroof, Overhead Console, Garage Door Opener, Body Control Module
15 - 10 Amp - Daytime Running Light Module (Canada)
16 - 20 Amp - Fog Light Indicator
17 - 10 Amp - ABS Control, Back Up Lights, Daytime Running Lights, A/C Heater Control Cavity Fuse Circuits
18 - 20 Amp - Power Amplifier, Horn
19 - 15 Amp - Overhead Console, Garage Door Opener, Trunk, Overhead, Rear Reading, and Visor Vanity Lights, Trunk Release Solenoid, Power Mirrors, Power Door Locks, Body Control Module, Aspirator Motor
20 - 20 Amp - Brake Lights
21 - 10 Amp - Leak Detection Pump, Low Rad Relay, High Rad Relay, A/C Clutch Relay
22 - 10 Amp - Airbag
23 - 30 Amp - Blower Motor, ATC Power Module
24 - 20 Amp - Power Window Motors
25 - 20 Amp - Power Door Lock Motors, Power Seats
Dash lights don't work when I turn on headlights
This is a problem with all trucks what you need to do is get the dash or cluster out and get it repaired at gm they send it out and after a few days it will be returned functional
2answers
Hid's not working
Check the wiring inside the headlight assy. I had a bad wire in a unit I installed. Once I tracked it down and repaired the wire all was fine.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
