Please use a bigger memory card to store more pictures, or delete old ones from your camera. You can safely do so, after you have copied them to your PC.
It means that the camera's internal (built-in) memory is full and cannot hold any more pictures. If you want to take more pictures, erase some of them first (make sure you download them to a computer first if you want to keep them). Alternatively, if your camera takes a memory card, put one in.
Are you sure that isn't "internal" memory card is full message?
Sometimes, when "internal
memory card is full" there is no more space in the camera's internal
memory. Your camera has 16 MB of internal memory. The number of pictures
you can store depends on the picture size setting you have selected on
your camera. Keep in mind that the
camera always uses internal memory, even if a card is installed (auto default).
If really, the problem is in the "SD memory card", I suggest make some backup all files and reformat the SD. Try formatting it in the camera, there should be a process in your owners manual for doing this; donw formatted SD in your computer, isn't good.
Your camera is talking about its internal memory. If you want the card to start working, you must get rid of the pics on the internal memory. With no card in the camera, go into the menu and find "format" and follow the on-screen instructions.
The internal memory is not the same as the memory card memory. The camera needs some elbowroom in the internal memory to work at all. It can't use the card memory while the internal memory is full. You need to delete some pictures from the internal memory, then insert the memory card, and it should work (assuming it is formatted correctly and is otherwise compatible).
The internal memory is the memory built into the camera, not the memory you put in with a memory card. This internal memory is rather small. If it is completely full, it will stop your camera working even with an empty memory card.
Take the card out of the camera, and delete some of the photos on the internal memory before you put it back in.
Your internal memory is separate from your memory card. Think of it as two folders, the internal memory cannot be removed, and the memory card is one you can take with you. You can put new memory cards in it all day, the internal memory will still have pictures in it. You may wish to consider copying all internal memory to the memory card. To do this, make sure your camera has a memory card in it. View pictures on your internal memory, then from the menu option select 'copy all images to external memory.' In doing this, all of your photos will be moved, you can then clean out your internal memory by deleting everything/formatting it. :)
Take out memory card from camera, format internal memory to delete all pictures at once or delete them one by one. Once memory card is inserted in camera, internal memory is no longer available to store/ delete pictures so remove memory card from camera to get access to internal memory.
u go to menu -hit down to where it says auto -it will bring up auto and
internal memory...hit internal...then u can delete your internal memory
the same way u do on your chip..
