Jamo SUB 200 Subwoofer Logo
Posted on Aug 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The fuse of Jamo Sub-200 gets blown off. is there anyone who might know the reason. thanks
Anonymous
Level 2:
New Friend:
  • Expert 142 Answers
  • Posted on Aug 26, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
142
Questions
0
Helped
29479
Points
402
Blown fuse indicates that current drawn is more then fuse's limit. there may be integrated ic failure or any other short circuit in amplifier. u need to check with a multimeter where is the short circuit.
Anonymous
Level 2:
  • Expert 155 Answers
Anonymous
Expert
Level 2:
Answers
155
Questions
0
Helped
37915
Points
523
Try replace the blown fuse with ampere and check the sound if still ok.
some fuse got blown if the load current exceed. maybe high volume can cause the high current.
other cause by short circuit coming from the amplifier.
1helpful
My Jamo sub 250, the R30 was blown. May I know the value of this resistor ? Anyone can help ?
If its still is defective in a corner or in the attic? Maybe you can make info by a KLIPSCH service centre because Klipsch is the owner of JAMO http://www.jamo.com/about/ if you have not find the answer.
Jamo About
I brourt a jamo sub 200 and five a102speakers but
The Jamo speakers need an AV Receiver to drive them properly. The TV doesn't have the correct outputs nor does it have the power required.
The Jamo kit consists of a powered subwoofer ans 5 small surround speakers. Each surround speaker needs to be powered by the speaker output from an an AV Receiver. The subwoofer should also be connected to the receiver, but the connection is a phono/RCA lead from the receiver's "Sub Out" socket.
Your TV connects to the AV receiver via the Optical out.
Hi My problem is that my Jamo 200 sub sounds very
Is everything hooked up correctly sounds off I know also could be your amp is going on you cold be a multitude of problems or one of the simple ones i stated
Jamo sub 250
Internal power? Check fuses. No fuses? Disassemble and check Power supply if it is internal. If it is external, check power supply with meter.;.
I have a jamo 200 sub and jamo s602 speaker how do i wire so i can listen to music from my ipad to the speakers
the easiest solution is to get yourself a cord that switches from headphone plug to RCA and connect it that way. I sure hope that this helps you in hooking your ipad up to the Jamo 200 Sub. Thanks, Cody
2answers
Jamo sub 660 wont come on
Hi,I have the Jamo sub 660 and it won't come on,I took it to my technician,and he told me that it has a broken ic,the broblem is that he cannot replace it cause the number on it is scratched,does anyone know what the number is pls! Thanks in advance Joseph
1helpful
Please help! Jamo SUB 300 subwoofer still blows (0.8A) fuses after replacing a faulty thermistor, despite a high ohms reading directly across AC mains terminals on the board. What is causing the fuse to...
hi,
i have a jamo 250 sub.the blue light is working.when i connect the jack to the left line IN according to the manual it makes a sound as well.but seems not working.is it related to the fuse????i know the fuse box.but i dont know how to remove the fuse to check.pls help me out.my receiver is onkyo tx-sr 608
thank you
ron
My jamo sub 200 & pioneer vsx517 receiver is not working properly
What do you mean that it sometimes doesn't work? It doesn't power on automatically?
Check settings of your receiver - if it has subwoofer output enables and if low frequencies from all channels are directed also to the SUB. By default only the LFE channel (.1) of 5.1 signal input is fed to the subwoofer. So Sub will work in this case only when you listen to 5.1 signal (DVD movie for example), but for radio or stereo music, only front speakers are used. By configuring this bass redirect, you can use subwoofer for all signal types.
Jamo Sub with no power
THE IS A FUSE INSIDE THE UNIT,YOU MAY WANT TO CHECK THAT.IF IT BLOWS AGAIN WHEN TURNED ON YOU HAVE SHORTED MOSFETS. THEY ARE LIKE TRANSISTORS.
Top Jamo Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Jamo Audio Player and Recorder Expert? Answer questions, earn points and help others
