Master
- Posted on Aug 26, 2011
Re: When hooked up to charger red light blinks. Light...
- Hi, i can help.
- When the lights just blink like that on the charger it is saying that the battery is bad and will no longer take a charge.
- These flashlight are real impressive but there have also been reports of the charging unit failing.
- Make sure to clean the contacts well with rubbing alcohol.
- I had one time that was a real pain if it was not set just perfect on the charger.
- So there are a couple things to try but I think you just need to get a new set of rechargeable. Lithium batteries like the ones this flashlight uses can't be overcharged or over discharged of they malfunction.
- CR123A Lithium rechargeables are cheap these days. spring on a new pair and you should be fine.
- If you have any comments please feel free to leave them here.
- Hope this helps and thank you for using FixYa.
Regards,
Tony
