Question about Casio FX-9750GPlus Calculator
When using my CASIO fx-CG10, I plugged in y={(x-3)^4 *divided by* 2}, but after trying to graph it by putting sketch or graph to table, it says invalid type
Posted by mkstovall on
k24674
  • Casio Master
  • 8,091 Answers
I may be imagining things, but I see curly brackets. That notation is reserverd for lists. Remove the brackets and you will see the graph.
Posted on Aug 26, 2011
Using disk
Download the ADD-INs from the Casio education website. You will find there the Installation instructions. Here is a screen capture for the relevant instructions. If the image is too small to read the contents, press CTRL and + to increase the size of the page.
Mar 04, 2014 | Casio FXCG10 PRIZM fx-CG10 Color Graphing...
I am not getting errors the icons are gone from the menu. the menu 1-G missing the rest.
The missing items in the menu correspond to the Add-On applications Geometry, Picture Plot, Conversion, Physium, and ProbSim.
You must download them from the Casio website and transfer them to the calculator. Download also the Add-On installer and follow the instructions.
Feb 20, 2014 | Casio Prizm FX-CG10 Color Graphing...
I cant figure out how to do log base formula
To calculate the log base b of x, divide the log of x by the log of b. You can use either the common log (log) or natural log (ln) as long as you use the same one for both.
For example, to calculate the log base 5 of 10, divide
log 10 by log 5
or
ln 10 by ln 5 .
Either way you should get about 1.43 .
Apr 12, 2013 | Casio Prizm FX-CG10 Color Graphing...
How do I find the permutations button on a Casio Computer FX-CG10 Graphing Calculator
Turn calculator ON.
If you see no icons, press the Menu key then [1] to select Run/Mat.
In Run/Mat press the OPTN key, then the F6 key to pan other tabs.
Above the F3 key you see the PROB tab. Activate it by pressing F3. The permutation Tab is above F2.
To use permutations, enter the larger number (n), press F2 [nPr] followed by the smaller number.
Jan 31, 2013 | Casio Computer FX-CG10 Graphing Calculator
Sketch the graph of the fuction F(X)=-X^2+5X-3
Press the Menu key. Use arrows to highlight the Graph utility. The function input screen opens so that you can type in the function
Y1=-X^2+5X-3You can play with the line style, or other features.
Press ENTER EXE to validate. Then Press the Function key to activate the Draw tab.
Oct 15, 2012 | Casio FX-9750GPlus Calculator
Syntax error for graphs
That hardly seems possible. Try graphing the function y=x.
There are a few ways to draw curves on this calculator
  1. Drawing functions
  • Type is y=f(X), the [X,theta, T] key enters X when pressed
  • Type POLAR r=f(theta), key [X,theta, T] enters theta w. pressed.
  • Type PARAMETRIC, requires an X=f(T) and Y=g(T) functions
  • Inequality graphing. You can also draw some functional inequalities such as y> 2X^2-3
  • Dynamic graphing (graphs where some parameter may be changing)
Drawing Relations
There are some other relation you can draw X=, X>, X< , and the drawing of general conics.
I hope that the foregoing remarks help you sort out the problem you are having. If they fail to do that, I suggest that you read the manual that shipped with your Prizm.
Sep 27, 2012 | Casio Prizm FX-CG10 Color Graphing...
How do i use the fx-300es to graph
Sorry but you cannot do that. This is not a graphing calculator. However you can generate a table of values for your function (MODE TABLE) and use it to graph the curve by hand (pencil and paper).
If you need a Casio graphing calculator, one of the cheaper ones is the Casio FX-9750GII. Equivalent Texas Instruments calculators are the TI83PLUS/TI84PLUS.
Aug 31, 2010 | Casio fx-300ES Calculator
How do i sketch a graph using a polar equation? i.e. r=a(1+cos "theta") this is for a casio 7400g plus btw
Apparently you cannot. Here are all the possible graph types available and there is no polar graph among them.
Mar 09, 2010 | Casio FX-7400G Plus Calculator
Casio FX-9750GPlus Calculator Logo
341 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Colin Stickland
Colin Stickland
Marvin
Marvin
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
