Question about Element Electronics FLX1911B 19 in. LCD TV
I need a tv base for a 19" FLX-1911B HD-LCD TELEVISION. THANKS!
Posted by tsturd1065 on
TvPartsGuy.com
    New Friend:
  • 30 Answers
TvPartsGuy.com carries lots of original pedestal stands for LCD & Plasma Tv's.
https://www.tvpartsguy.com . use coupon code: fixya10 for 10% off your stand.
Posted on Dec 10, 2011
I purchased an element electronics 32" Full HD digital LCD from Walmart with a Ready Set Mount LCD/Plasma Wall Mount, however the mount does not attach to the tv at the base. Do you know if this is...
The wall mount is not made to be fit into the base, it is attached to the back the TV, TV uses what they call VESA mounting which had different pattern for each TV. Look at your TV user manual to find out the VESA mounting number.
If you want TV wall mount that can swivel you can try looking here: http://www.mountsdirect.com//index.php?cPath=1_4&osCsid=b3fd26fc27f668e207c3741b09abfe51&gclid=CJrL-5Dx1acCFYrs7QodUiUq9Q
http://www.toptvmounts.com/collections/swivel-tv-mounts?gclid=CK7kzPrx1acCFYXu7QodlFc4-A
Or Google "swivel wall mount"
I got my from COSTCO.
Mar 17, 2011 | Element Electronics FLX-3211B 32 in. LCD...
How do i set up the HD on my television?
You need to have the HD cable and on your output Menu you will see HDTV 1 . Select HDTV there and if you have everything well connected it will work well.
Nov 20, 2010 | Element Electronics FLX-1910 19 in. LCD...
Can't remove stand from Element flx 1910 TV.
On the bottom of the Element FLX-1910 there are 4 tabs located on the bottom side of the base. With the help of another person, please slide all 4 tabs in an inward direction. This will release the tension between the base and the stand. Slide the base over the tabs and remove the base from the stand.
Apr 12, 2009 | Element Electronics FLX-1910 19 in. LCD...
My element 19 inch flx-1910 tv will not power up
did you make sure the voltage, amperage, and polarity were matched tv to plug?  The information is found on the back of your tv and the plug must match that.  If they do not match, you might have fried your tv.
Mar 11, 2009 | Proscan 19LA25Q 19 in. LCD Television
Need code for Element 15" FLX-1511B HD LCD Television
Try this site -> http://www22.verizon.com/ResidentialHelp/FiOSTV/Remote+Controls/SetUp/QuestionsOne/122830.htm
Aug 10, 2008 | Motorola Mobility DRC800 Universal Remote...
Element Electronics FLX1911B 19 in. LCD TV Logo
177 people viewed this question
Top Element Electronics Televison & Video Experts
Daniel Dollive
Daniel Dollive
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
