Question about Nikon COOLPIX L4 Digital Camera
My flash stopped working on my nikon coolpix L110..
Posted by kmiller61963 on
Eury Satorre
  • 957 Answers
The Nikon Coolpix is a compact digital camera that is well-suited for amateur to semi-professional photographers. Occasionally, some issues with the built-in flash can occur. If the hardware is damaged, the camera must be taken in for repairs. More often, problems occur because of obstructions or issues with the camera's settings and are easily repairable. Follow the troubleshooting guide to fix the built-in flash.
Instructions:
1.Ensure the Nikon Coolpix digital camera battery is fully charged.
2.Wait several seconds before pressing the shutter-release button if the "Flash Ready" indicator light is flashing red. Press the "Flash Mode" button once or twice to change the flash settings from "Off" to "On" or "Auto" if the "Flash Ready" indicator light is off.
3.Ensure there are no obstructions, like your finger or the camera strap, that are preventing the flash from firing if an error message appears on the display screen and the flash is not firing when the flash mode is set to automatic.
4.Press the flash back into the camera after every photo to ensure the flash always fires in "Auto" mode instead of just in low illumination settings. Press the flash back into the camera to turn off the flash in "Manual" mode; otherwise the flash will continually fire.
5.Change the auto focus setting from "Infinity" to "Auto," "Macro Closeup" or "Self-Timer" by pressing the "Focus Mode" button once, twice or three times to automatically turn the flash back on.
6.Use only Nikon external flash accessories to avoid damage to the built-in flash and camera circuits.
I hope you find it very helpful. Thanks.
Posted on Aug 25, 2011
How do i fix my burnt out flash bulb for a nikon coolpix L110?
If your flash bulb is burnt out, so replace it by a new. also replace the four flexible connecting wires. But be very careful of high voltage may damage the whole camera.
Jun 17, 2012 | Nikon Coolpix L110 Digital Camera
My Nikon coolpix L110 is not responding at all or takes forever to respond
Try resetting the camera by removing the battery for 15 mins, then insert the battery and go into the Menu to set the Date and Time.
Mar 20, 2012 | Nikon Coolpix L110 Digital Camera
Nikon coolpix L110 flash blown. how to replace and how much?
a flash bulb is burned, the burning smell came out. L105 is compatible with? which is found in ebay and is similar to a view.
regards
Jan 26, 2012 | Nikon Coolpix L110 Digital Camera
The flash not work. I want service manual
To download the repair/service manual use the link below:
http://dc270.4shared.com/download/l6dac6yt/Nikon_Coolpix_L100-110_Repair_.pdf?tsid=20111101-201311-4d54a07b
Note: You must have Adobe Acrobat Reader installed to view PDF files. The reader is a free plug-in available at the Adobe web site .
Nov 01, 2011 | Nikon Coolpix L110 Digital Camera
The pop up flash stopped working on my Nikon Coolpix L110 camera. Camera still works, but without the flash, the pictures are less than desirable. What can I do to correct this problem?
Check your settings first. If this still doesn't work then you'll have to take/send your camera to an authorized Nikon service center.
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10003
212-673-8400
Jul 01, 2011 | Nikon Coolpix L110 Digital Camera
If the flash is up or down my pictures come out blurry on my nikon coolpix l110
Hiyour describe is not clear, would you provide the problem step by step and sequence? I would like to help.
Jun 02, 2011 | Nikon Coolpix L110 Digital Camera
My nikon l110 flash camera doesnt flash.
Hi , may be xenon tube bad and need to be replaced.
Contact service station.
Regards
Mar 12, 2011 | Nikon Coolpix L110 Digital Camera
Nikon COOLPIX L4 Digital Camera Logo
1,054 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Nikon Camera Expert? Answer questions, earn points and help others
