RCA HD56W66 56" HDTV Logo
Posted on Aug 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I HAVE A 56"
Sonny Berry
Level 3:
  • RCA Master 8,617 Answers
  • Posted on Aug 26, 2011
Sonny Berry
RCA Master
Level 3:
Answers
8617
Questions
Helped
1723013
Points
23750
Thats called the front keyboard its available from www.tvrepairworld.com under RCA circuit boards.
2helpful
Calibrate rca hd56w66
This is a common problem on this model. Call in a shop or do it yourself with parts and instructions from www.TvRepairKits.com
Rca hd56w66 no power not even the green light power board looks good suggestions to find the problem?
Check the fuse. Its located on the right side looking in the rear of the TV its the small board where the power cord plugs into. The fuse is on that board.
The convergence box keeps going out.
this 3d effect is due to what is known as convergence.i work daily on these set in the shop. (thats a good testomony for these LOL) but the first question i ask is 1 in the customer setup do you have convergence option.. Next question is the picture bow tie looking and 3d. if you are missing the convergence option chances are it is the fl231 fuse. then you need to read the fl231 fuse under tips and tricks section of this website. Convegence is controled by three cuicit boards. if any of these need to be replace a technician may need to set or adjust the convergence back to faactory specs
FL231 fuse on RCA hd56w66??
the rca itc222 comes in both 56 and 52 version.. If you do not have the convergence option in the customer menu under setup then there is a high chance that the fuse will be the trouble
Rca hd56w66
reset? i know of no reset button on this set what are you trying to reset... whats your complaint on your set. I repair about 10 of these a week at the shop. so let me know if i can talk you through it. leaveing the set unpluged for 30 minutes is standard reset
2answers
Picture too tall
first to change format push the arrow button to the left or right. if you go into piicture in the menu then go to avance picture settings then turnoff or uncheck autoformat.
Hd56w66
you need a new convergence power supply or the actual convergence amp board. Go to this link and they will be able to help you with the problem . Just leave your model number and problem your having in an email to them.
http://servicemanuals.vstore.ca/
Firmware upgrade
firmware upgrade? i am not aware you can ungrade the firmware on this set this is a rca itc222 chasis. there is service software that allows you to diagnose problems. rca offers no firmware update for this set
Covergence problem
press and hold menu then push power then volume.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
