Yes, but you need a few things.
1. First you need a VGA adapter on your laptop (you should have one if you have a model made within the last several years)
2. Next you need to see if there is one on your TV
3. Last, you need a VGA cable to connect the two.
4. After they are connected, you can enter the setup menu or input menu of your tv and select the VGA option to see your computer on your TV.
Note that this method WILL NOT also provide sound through the TV, just pictures. On newer models of laptops, HD connections are provided, and you could use an HD cable to connect your TV to the laptop. In this instance, sound would be able to come through the TV.
Hope this helps!
