Question about Apacer Memory Apacer AU231 MP3 Player
I have a Apacer Audio Steno AU231 and when i plugged into my new computer with Windos 7, the computer didn't recognise him and I can't use my Apacer Audio Steno AU231 because the drivers for Windows 98 doesn't run with my new computer... I can not find the right driver to run my MP3 player... can you help me ?
Posted by kmasson_info on
1 Related Answer
bobhifi
Jacob Paul
  • 635 Answers
SOURCE: Hi, I have an old
Your balance 247MB files must be write protected. You will have to untick the protect tab and then delete. Or else you can connect the device to your computer and right click on the AV220 icon and click on the format command.It will warn you that you will loose all data -- just ignore it and click yes.
Posted on Mar 07, 2011
Testimonial: "Fast and very helpfull respons! Thanks!"
Hi, I have an old Apacer Audio Steno AV220 mp3-player. After deleting all visible files and folders, there are still only 11MB avaiable (out of 247MB). I guess I need to formate it(?) but how do I do that?...
Mar 07, 2011 | Apacer Memory Audio Steno AV220 MP3 Player
Repeats songs
Check to see if the song repeat function is enabled, it is probably in the device settings.
Feb 17, 2011 | Apacer Memory Apacer AU231 MP3 Player
My mp4 cant ready files whats the problem
Welcome to fixya
I have a solution for this, Please follow up with me if you need more information. Content
Please remove and then reinstall the batteries. DO not use rechargable batteries as they are known to cause lots of errors.
More information is available in the comments
My name is Bruce
Jan 20, 2011 | Apacer Memory Apacer AU231 MP3 Player
J ai le mp3 tout le temps allume et il ne   fonctionne pas
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} ok tu peut essayer de la formater
Suivre les étapes suivant:
cliquer le : Setting>Control Panel>Administrative Tools>Computer Management>Disk management>
essayer de la formater en fat 32 et fat nfts
Merci
uttam
Jan 13, 2010 | Apacer Memory APACER AUDIO STENO AV220 1GB...
Hello,I cannot access my 1GB apacer mp3 so plzzz help me to start that...
Plug it in and see if it shows up in my computer if not then install the drivers off the CD that came with it
Dec 02, 2009 | Apacer Memory APACER AUDIO STENO AV220 1GB...
My mp3 doesn't charge
The battery may be depleted and unable to recharge completely.
Mar 04, 2018 | Apacer Memory Apacer Audio Steno AU822 ...
NEXT SONG PROBLEM
Is it possiable you have it set to repeat?
Jan 10, 2008 | Apacer Memory Apacer AU231 MP3 Player
Can't re-synchronize deleted files
your gonna have to reinstall all your stuff as I always tell peeps if you need to reformat or clean up your files and you got alot of data you should always have a copy or backup files on your puter. Sorry
Apr 11, 2006 | Apacer Memory APACER AUDIO STENO AV220 1GB...
Apacer Memory Apacer AU231  MP3 Player Logo
123 people viewed this question
Top Apacer Memory Audio Players & Recorders Experts
Michael Thomas
Michael Thomas
vinayghl
Tom Chichester
Are you an Apacer Memory Audio Player and Recorder Expert? Answer questions, earn points and help others
