Error codes are only of use by the Toshiba Technical staff and of no use to you as the consumer.
If you report that to the Toshiba Technical personnel, they can transcribe the error number for you.
If a blinking light comes on when charging, sometimes it indicates No Charge or the power cell inside the computer is not accepting a charge and will not function. You might replace the power battery if it has been in there for several years. They do tend to die after a while. As for the computer, it should operated without the battery. If it fails to boot when the power adapter is plugged in, then one of two issues are common. 1, the power adapter is faulty and needs replacement. 2. the computers CPU may be damaged by a power surge and that is bad news.
SOURCE: i have a toshiba tecra m4-s435. i plug it in to
you can try also format your toshiba tecra m4-s435 and
