Question about Toro& Electric String Trimmer
Do you know what the proper Champion part number is for a Toro 51972 weed trimmer is? This was purchased used and it had a RCJ4 Champion plug in it and I just need to verify that this is the correct plug. The trimmer won't start and I want to start there with trying to solve the problem.
Posted by tlohse on
melzar reyes
    New Friend:
  • 46 Answers
That is the correct spark plug for the unit. i work at a power equipment store where we work on homelites. 90% of the time it wont start or run right is usually carb issues . need to get it rebuild or replaced
Posted on Sep 21, 2011
Toro manual weed eater model 51974
Jul 10, 2008 ... All Weed Eater brand gas trimmers require that oil be added to the gas in a ratio of 40:1,
You can Google these questions
Jul 06, 2018 | Toro Garden
What is the Gap set to on the RCJ6Y Homelite trimmer
25 thou. 0.0025
OPERATOR'S MANUAL MightyLite 26cc VersaTool String Trimmer ...
https://www.gardnerinc.com/manuals/.../Homelite/string%20trimmers/.../UT21566_96...
Your trimmer has been engineered and manufactured to our high standard for dependability, ease of operation, and ..... Mix Homelite Premium Exact Mix lubricant with gasoline .... This engine uses a Champion RCJ6Y or equivalent spark.
SOLVED: The sparkplug RCJ6Y can you tell what the gap is - Fixya
www.fixya.com/support/t6293374-sparkplug_rcj6y_tell_gap Oct 5, 2010 - The gap for a similar Homelite is .025". I didn't find your exact model. I think you have the 26cc engine. Here is a user manual from similar ... gap champion rcj6y spark plug Questions & Answers ...
Apr. 1, 2015
Weed eater spark plug gap for champion rcj6y for ...
Jun. 16, 2012
SOLVED: What .000s is gap for champion plug RCJ6Y
Aug. 28, 2011
rcj6y champion Questions & Answers (with Pictures)
Apr. 17, 2011
More results from www.fixya.com
Jun 04, 2018 | Homelite Garden
Replace head on toro model #51954 curved shaft trimmers
https://video.search.yahoo.com/yhs/search;_ylt=AwrTcdIyalFXg.QAUmAnnIlQ;_ylu=X3oDMTByNWU4cGh1BGNvbG8DZ3ExBHBvcwMxBHZ0aWQDBHNlYwNzYw--?p=Toro+Model+51954+Weed+Trimmer+Owner+Manual&fr=ytff1-msgr&hspart=mozilla&hsimp=yhs-006
Jun 01, 2016 | Toro Garden
Replace AC49 spark plug witha champion plug number
You either have an incomplete number for your AC spark plug or it is a very old, unusual or obsolete type because there are no equivalents for that number.
I suggest instead of trying to find an equivalent you should use the make and model number of your appliance and buy the recommended spark plug from the application catalogue of your choice. I am not fond of Champion plugs for no particular reason and prefer NGK.
Apr 25, 2015 | Toro Garden
My weed eater (toro), won't let me pull the cord at all. This weed eater doesn't take oil I don't think.
All internal combustion engines use oil of some description. I take it this is a 2 cycle engine and you have not added oil to the gas. If this is the case the engine is locked up, and must be replaced. Sorry.
Mar 25, 2012 | Toro& Electric String Trimmer
My Toro 12" Trimmer (Weed eater) needs a new screw down cap to hold the spool in place. Home Depot no longer carries them. That's wheree I got the last two Weedeaters.Please give me instructions as to...
Your Toro electric trimmer parts are readily available through www.partstree.com . However, to avoid having to pay $10 in shipping for a $5 part, you should try to find your local Toro dealer. They probably have the part in stock. Go to www.toro.com and search on the dealer/distributor locator to find your closest dealer.
You will need to know the model number (5 digit) and serial number for your trimmer. These can be located on a small sticker on the trimmer.
Oct 14, 2010 | Toro& Electric String Trimmer
Trying to find a owners manual for a Toro grass trimmer model 51972
you can get it here: https://lookup3.toro.com/request/request.cfm
print for free or purchase copy
Sep 13, 2009 | Garden
Toro& Electric String Trimmer Logo
312 people viewed this question
Top Toro Garden Experts
Dennis Key
Dennis Key
Marvin
Marvin
dannydoesita
Are you a Toro Garden Expert? Answer questions, earn points and help others
